Generator to Chevy Alternator Conversion
I'm fixing a buddies' '61 Facel Vega. I'm not much for foreign cars, but this one is pretty darn cool.
Anyway, Doc was super helpful figuring out the starter wiring and now I need to figure out how to wire the chevy alternator (early style) with the existing harness. From the stock regulator I have 3 wires. 1) from the ARM post 2) from the FLD post and 3)from the top mounting post which I believe is a ground There is no wire available from the BAT post. Can I rewire this to work with the Chevy Alternator? Thanks. |
Doc here,
What type Alternator do you plan to use? The Delco SI Series, or the CS series, and will it be internally regulated or externally regulated, one wire or three wire, Care if the charge lamp works or not..? There is a primer at Mad Electrical site here: Mad Electrical That will help you decide..when you have picked the system , post back with which one, and we can provide you with the wiring for it. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
reply
Thanks Doc.
It has an alternator which is the older style (not sure of the #). it had the plug a that is horizontal - I I . It looks like it's from the early 70's. I'm guessing it's a 10SI? It's externally regulated, I want to stick with 3 wire and I don't care about the dummy light. |
Doc here,
Simple... Run a 10 gauge wire from the solenoid Battery Cable bolt , Via a proper fuse link, To the BATT (or big lug on the back of the alternator) . Next, Run the small red from the top plug to the Big cable on the back of the alternator. Next , run the brown wire from the top plug to the lamp / Switch / Bypass circuit existing in the car. (it too should be brown , on the old regulator) This will give you a basic charge system, with idiot lamp. Test it for proper operation, Then remove and abandon the old regulator. Tie back and properly insulate the wires from the regulator..BTW , the reds on the regulator may need to be connected together...to work right. ![]() ![]() Doc
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| 9" to chevy conversion | bigiron | Transmission - Rearend | 4 | 10-11-2005 10:32 PM |
| 36-39 Chevy Sedan frames | Rufus_2 | General Rodding Tech | 5 | 09-02-2004 12:52 PM |
| Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? | mistermuscles | Transmission - Rearend | 0 | 07-18-2004 05:40 PM |
| New Member Introduction - 48 Chevy Rodder | 48 Chevy Rodder | Hotrodders' Lounge | 0 | 10-20-2001 03:04 AM |
