Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Generator Question
Old 12-23-2004, 08:13 AM
daimon1054's Avatar
daimon1054 daimon1054 is offline
Originally posted by julmer
Be darned careful about putting any kind of enclosure around an air cooled engine assembly. If you keep all the sound in, you may keep all the heat in also and you will end up with an expensive crispy critter.
I was at an RV site the other night. 5KW RV unit brand new is about $3000, Used should easily be less than 1/2 that. Also, all the RV style ones are electric start - that's a nice feature.
If you were to use a car-sized muffler, you would want to leave the stock one in place to generate the proper back pressure for the engine.
Your right about locking in heat, I was a litle vague. All you need is 3 sides and a partial top to reflect the sound away from the shop. Keep the walls about 1 foot from the generator so the air can move.
