Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Get Ready to Topcoat or Seal first
Old 10-07-2011, 02:47 PM
roger1's Avatar
roger1 roger1 is offline
Guaranteed, you will get halos around each sand-thru after spaying sealer.
Which leaves you with a couple of options, sand the sealer (if it's one that CAN be sanded) or, spray your base on top, sand that and then spray a final coat of base.
Some sealers (and some epoxies) are not sandable. I use a reduced epoxy (that is sandable) for a sealer.
Addition:
I just thought of the possibility you are using ss (that you don't intend to color sand) and not bc/cc.
If that's the case, I would shoot a coat of sandable epoxy, block it with 400, then shoot another coat of reduced epoxy as a sealer before your topcoat.
I'm not saying that's the only way to do it. But, it's what I would do.
