Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Get Ready to Topcoat or Seal first
  #19 (permalink)
Old 03-27-2012, 02:14 PM
hemiguy hemiguy is offline
Well, sounds like what you are doing is fine, I don't know why it should spray so thick or dry. Are you setting air pressure at the gun?
Mix 4:1:1 - medium build
Normal shop temp is 77 degrees
Siphon Feed 1.6-2.0mm 40-50 psi
Gravity Feed 1.6-1.8mm 35-45 psi
HVLP 1.6-1.8mm 10 psi
For curved areas you need a curved or rubber block. Basically anything to wrap the paper around.
I don't quite understand how the scotchbrite pads are helping?
Keep at it, you are learning a lot as you go!
Originally Posted by dr.strangelove
Thank you for the writeup, I'll try to answer your questions the best I can...
What kind of high build primer are you using?
ProForm 2K Urethane Primer Surfacer PF 656C
Are you mixing it according to directions?
The first application I used it as high build, the second time I added reducer as per the manufacturers instructions to use as a sealer
What temperature are you spraying at?
-When I sprayed it was about 20 C / 68 F
Is it spraying too dry?
-Yes, even when I used reducer with it.
What gun and tip do you have?
-1.7mm
Are you waiting between coats?
-It went on so thick I only laid one coat.
It is not a good idea to add more reducer to get it to flow. This can lead to a too thick build and solvent popping.
-I'm not sure that I added too much. the first time I sprayed I didn't add any and the surface was not smooth after spraying. Also, it takes a lot to sand down to a surface that is flat (not pitted).
