Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Get Ready to Topcoat or Seal first
  #20 (permalink)
Old 03-27-2012, 04:32 PM
dr.strangelove dr.strangelove is offline
the scotchbrite doesn't seem to clog nealy as much as the sandpaper and I wasn't sure if I should wetsand. As I mentioned there are a few spots of bare metal and I don't know if the primer will like getting wet. I read the data sheet for the primer I listed above (high-build), but it doesn't say anything about wetsanding. I've made every mistake in the book, except for that one so far ...and then again I could be making a mistake by not wetsanding too!
My next purchase is going to be a set of flexible durablocks. I find with the longboard it's easy to apply too much pressure to the centre of curves. In the case of my good, which has a slight radius, everytime I go over the centre it is pushed down slightly.
