Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Get Ready to Topcoat or Seal first
  #37 (permalink)
Old 09-24-2012, 06:45 PM
novafreek6872's Avatar
novafreek6872 novafreek6872 is offline
Nova Guru
Originally Posted by dr.strangelove View Post
Thanks for the reply Andy. Judging by how your car turned out, I'd say your advice is probably spot on. I ran out of final wipe though, and the supply shop isn't open on weekends anymore. I have some old (2-3 years) final wash, but I'm kind of worried about using it. Should this be a concern?
Not sure about the W&G remover. I used some prep stuff that came in a spray can I got at the paint store. I always used it the night before painting, that way there was no question it would flash off.
And you got me thinking, if your car has been sitting for awhile with that sanded epoxy on it, it couldn't be a bad idea just to go over the whole thing lightly with a grey scuff pad the night b4 you are going to paint. That epoxy gets pretty hard and you don't want any adhesion problems. Then do the final wipe down.
Next morning, mix paint, tack the car off and you are good to go.
Andy
