I have already epoxied the body and applied a high build urethane primer. The primer has been sanded in most places with 220 grit paper, dry. The high build left a lot of orange peel and required some pretty extensive sanding. As a result I have sanded a lot of the high build off and have reached my epoxy in some places.
My question is: should I apply another coat of the urethane primer 1) as a sealer, 2) as a medium build, or 3)finish sanding with 400, then 600, and topcoat?
See pictures for reference...
Also, top coat is a single stage urethane (Gloss Black Delfleet essential, specifically)
It's too much gap there between 320 and 600. What works best for me is 320 dry and then (after couple more coats of primer) 400-600.
Of course you would 320 wet and give it a coat or two more and then finish off with 600.
Dr.Strangelove's Running Nightmare - Body Lines and Wheel Arches
Happy Friday Ladies and Gents,
With the impending clear skies this weekend, I INTEND to paint my car.
I must be doing something wrong, because I am constantly sanding through my primer and find myself repeating this process to the detrement of my bank account. As such, I'm going to put in another 10 hours of sanding to leave the car in 220 scratches, before spraying a couple of coats of epoxy on everything and topcoating.
There have been a number of factors that have contributed to the delays over the course of this project, but the one I am facing now is dull body lines, especially those that appear around the fender arches.
Does anyone have any advice for a poor SOB who wants to give one last shot at cutting some nice lines into this car before I completely botch it?
I've attached two photos, one of a car with proper lines (notice the definition between the fender/quarter panel flat and wheel arch (you know those warning/waxing moon crescent shapes), and the second two of my car with its rough, poorly defined, body.
your bodywork looks good, however I'd recommend putting 2-3 coats of high build 2k primer over it and wet sanding whole thing with 400 and then seal it and paint it.
I was in the same hole but all that sanding and re-sanding just means that your panels are not blocked. It will all pay off in the end. What I was runing across this I would start with 220 finish with 400 before adding another coat if the bottom coat was showing again. after a few times I shot a heavy coat of G5 feather fill that fills more than Urethane primer. that made it the final coat of primer I had to block. I then applied a coat of Urethane and wetsanded to use as the sealer.
My first car Im very very happy with how straight my panels came out
thanks again for your help. i made some good progress on the blocking front yesterday. i had some cracks around the front fenders to sand out and some other imperfections to fix. the plan now is to nail the body work before applying more primer. the high-build filled, but i had to sand most of it off because there were a lot of pin holes to sand out. to mitigate these small holes in the future, i've picked up some flow through fittings. hopefully the gun won't clog up as much, but i'm still contemplating using putty and going straight to epoxy. i know the epoxy is harder to sand (at least the proform that i'm using), but my experience with the high build has been really bad. I'm going to check with the auto supply store tomorrow and see about picking up some featherfill, as suggested. My roof, hood and hatch look good. the side panels, however, I cannot tell, because there are so many different shades and colours that are distracting to the eye. When i go over the panels with the block they seem pretty straight though. i'll try to get some pics out in the sun--will touch back with you after i get some more work done.
what shape blocks do you recommend for the wheel arches?
Although I'm not finished, I feel like I've made good progress. Here's the latest.
Rockers, inner fenders/inner quarter panels, door/hatch/hood jams, fueling compartment, trim pieces all have received 2 coats of epoxy with no problems.
Outer body panels all have one coat of epoxy, but temps were low and my gun leaked, so I wanted to do some more sanding. As such, I've used the finest grit I have at the moment (220) to level the surface again before applying another coat of epoxy. I've only done 30% of the car and so far I have no burn-through.
Here are my questions:
1-On panels with no runs, should I skip the 220 and just go with 400 before sealing the entire car or sand the whole car in 220, epoxy the whole thing again and then 400-600 and paint?
I think I'm getting better at sanding, because I managed to do the whole car last night. On the other hand, the closer you get to the end the better the panels are to begin with. I only have sand-through in a few spots, but I'll be reapplying at least one more coat of epoxy to everything, sanding with 400, sealing with a reduced epoxy and painting.
Also, I've decided to retire the cheap spray gun I bought as part of a three-gun kit last year. It leaks like crazy and the seals inside have completely disintegrated. The new one I picked up is cheap as well, but feels much smoother. I'm debating using the same one to spray the top coat, but I've learned that leaving things to chance often results in the worst case scenario!
Seems like you could spot prime the sand through spots, sand with 400 or 600, then go straight to base/ clear. Skip the reduced epoxy as sealer step and not have to sand the entire car AGAIN.
Thanks for the reply Andy. Judging by how your car turned out, I'd say your advice is probably spot on. I ran out of final wipe though, and the supply shop isn't open on weekends anymore. I have some old (2-3 years) final wash, but I'm kind of worried about using it. Should this be a concern?
Not sure about the W&G remover. I used some prep stuff that came in a spray can I got at the paint store. I always used it the night before painting, that way there was no question it would flash off.
And you got me thinking, if your car has been sitting for awhile with that sanded epoxy on it, it couldn't be a bad idea just to go over the whole thing lightly with a grey scuff pad the night b4 you are going to paint. That epoxy gets pretty hard and you don't want any adhesion problems. Then do the final wipe down.
Next morning, mix paint, tack the car off and you are good to go.
That's a good point. I noticed the epoxy in some areas keeps a 'wet look' after the final wipe in other areas has flashed off. I ended up using the final wipe I had from a few years back and it seems to be the same stuff, only it is in an unbranded container.
I just cleaned out my new gun and I'm waiting for a plus 20C day to lay down more epoxy. I figure I might as well use what's left, but I'm not going to bother with the sealer. To date I haven't had much success spraying anything that was good enough to cover as is.
While I did most of the work, I have to give credit to the owner of the shop who did an amazing job shooting the car last night. Thanks also to everyone on the forum who helped me out with advice along the way. Hopefully turnaround on the next project is faster. I'll post more pictures when the car is back together.
It's pretty damn straight, unfortunately there is a bit of dust or grit in the paint. I'm afraid to sand it though, because I don't want to take the paint off if the dirt is all the way down to the substrate.
The next project is going to be building a downdraft booth in my next house so that I don't get dirt in my next paint job The walls of the booth I used this time were rusty and full of holes. I probably would have been better off leaving the fans off, as I'm sure a lot of dirt bypassed the filters through cracks, holes, etc,.
I promised my wife that I wouldn't buy any more cars until the ones we have are fully operational, but I have always wanted a nice black Volvo 240 wagon with a big turbo.
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
