Get rid of drive by wire - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 04-04-2012, 10:02 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
I've done a search for this but can't seem to come up with a solution.
I have an '03 or '04 5.3 LS1 going into a '37 Chevrolet. I do not want the drive by wire. How can I get rid of this system and use the old rod or cable system.
Please don't convince me to try to keep the drive by wire. I don't care to do that.
Thanks,
Brandon
Old 04-04-2012, 10:31 PM
Wiki Edits: 31
1999-2001 cable drive setup, but it may need ECU and wire harness also.. It may be easier to butcher the original pedal up to get just the resistor out of it, hook it somewhere under the dash and put a cable on that
Old 04-04-2012, 10:47 PM
Vetteman61's Avatar
I don't currently have an ECU and I'm going to have to have a harness made so those are real big issues for me. So would I have to get another throttle body and install it?
thanks,
Brandon
Old 04-04-2012, 10:48 PM
evolvo's Avatar
Heathen
OK, so you don't want to be talked into keeping DBW. But your installing an LS1 that has electronic injectors, crank position sensor, cam position sensor, inlet air temp sensor, knock sensors, mass airflow sensor and probably an electronic transmission all controlled by an ECU but you want a cable operated throttle pedal! When for about $105 you could have one of these http://www.lokar.com/product-pgs/new...e-by-wire.html and avoid countless headaches. Far be it from me to convince you otherwise
So I was writing when you put up your last post: If you need to have a harness made just have them include DBW, easy peasy.
Old 04-04-2012, 11:04 PM
Vetteman61's Avatar
Yeah, that pretty much sums it up.
Old 04-04-2012, 11:09 PM
evolvo's Avatar
Heathen
OK, just wanted to be clear
Old 04-05-2012, 08:07 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
thanks,
Brandon
just curious
do you have this part figured out already?
trans also?
and what are you using for a chassis wire harness?
Old 04-05-2012, 10:20 AM
Vetteman61's Avatar
I haven't figured this out yet. I'm using a 4l60E trans. I'm going to be working on this in the new few coming weeks and am trying to get ideas on the best way to make it happen.
Brandon
Old 04-05-2012, 11:14 AM
I don't understand?
Brandon
it wouldn't be cheap, but I think the easiest/cleanest way, would be to talk to painless wire
I would bet they have a kit for the whole thing or at least point you in the right direction
Old 04-05-2012, 12:46 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Thanks,
Brandon
The easiest way to do a late model transplant is to take as much of the original as possible and use it. I have not seen you post a reason as to why you dont want dbw.
Old 04-05-2012, 01:44 PM
Vetteman61's Avatar
I'm not trying to be confrontational at all, but in all honesty if we all wanted to do things the easiest way we wouldn't be building our own cars. I think the reason most of us do it is so that we enjoy engineering and also so we can build our cars the way that suits us. That way we don't have to worry about the problem of having things the way most people want them when you deal with mass produced items.
I'll check in with the harness provider when I call them and see what they have to say.
Brandon
Old 04-05-2012, 01:55 PM
TurboS10's Avatar
Wiki Edits: 2
As someone who worked as a controls engineer for 6 years and built and tuned 3 diy ECU's I am telling you that if you have to ask the question then it is much more work than you want to deal with. Removing it is not just a matter of rewiring and any information your "harness provider" can give you will be of no use at all when it come to actually making it work.
Now, there may be a solution out there for this since the swaps are getting very popular, but it will not just be a wiring change and throwing a throttle cable on it.
I am simply asking why you want to do it?
Old 04-05-2012, 02:09 PM
Vetteman61's Avatar
I just talked to the guy who's going to do my harness. He's from Speartech. He said it's as simple as putting a 99-02 throttle body on it and using an ECM from a 99-02 vehicle.
That's easier than I had thought.
Talking to him on the phone has be pretty anxious about if I'm going to be able to hook all the electronics on this motor up correctly, but I've heard people in the past say it's pretty much foolproof. I guess I'll attempt to prove them wrong.
Brandon
35WINDOW's Avatar
Last journal entry: Engine!
I am trying to think of a way to operate a 4L60E without a TPS Sensor? Maybe only in manual mode?
Old 04-05-2012, 02:59 PM
TurboS10's Avatar
Wiki Edits: 2
Glad you have a solution in mind. I dont understand why you would want to have to find more parts when you have everything you need including a harness, but its your project. I can promise one thing; it will be a learning experience.
Recent Modern Electronic Engines posts with photos
Drive by Wire CurtisLr Electrical 5 07-19-2007 08:44 AM
Drive by wire Animal Electrical 39 02-07-2006 06:02 PM
Drive by wire lindanjustin Engine 10 02-05-2005 07:45 PM
Drive by wire system 33TRANSPLANT Engine 0 03-19-2003 08:21 AM
