Getting .525 lift out of 906 Vortec Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2011, 09:53 PM
I want to run an LT4 hotcam with a set of 906 Vortec heads. I got this much so far for parts:
http://www.summitracing.com/parts/CCA-26918-16/
http://www.summitracing.com/parts/NAL-24502586/
http://www.summitracing.com/parts/PRO-66914/
What locks and retainers would I have to get? I was told without machine work I would need to run offset locks but I can't find what I need because I don't know about this valvetrain stuff. Stock I've heard that the 906's will do about .475 lift, I know I need beffier springs and I have them picked out, and I know running more lift on them would more than likely be a clearance issue, but offset locks should fix the problem right? I'd appreciate the help, thanks guys.
Old 12-14-2011, 10:37 PM
psbaker75's Avatar
I had interference issues with my vortec heads too, I bought a valve guide cutter and valve seat cutter from summit and did it myself. Took a couple of hours with my drill, but I got it done no problem. Just make sure to check and doublecheck your clearances before you put it all back together. Once I got the first one set, I used a straight edge to get them all lined up. If I can find the thread from when I did it, I'll link it here for you, but it wasn't tough at all, and the tools only cost about a hundred bucks.
Old 12-14-2011, 10:51 PM
psbaker75's Avatar
http://www.hotrodders.com/forum/brok...st1388196.html
there is the link for the thread. I have all of the parts numbers for the tools i used to do mine. fbird88 also had some good tips that helped me immensely (post right after i give the parts numbers). it was a really easy operation and saved me a ton of money over more expensive springs, retainers, locks, etc... didn't mess with my installed spring height, and cost considerably less than if i had brought it to a machine shop to have them do the same thing.
Old 12-14-2011, 11:08 PM
V305's Avatar
On the Border
Good reading, info and pics here:
http://www.pacificp.com/forum/viewto...&highlight=787
http://www.carcraft.com/techarticles...ade/index.html
Old 12-15-2011, 12:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That CC article has the retainers to use the bee hive springs on the Vortec heads as p/n 774. This is wrong- the 774 retainer is for the LS-type Gen III engine w/8mm valve stems. The correct retainer for Vortec heads is p/n 787.
Old 12-15-2011, 12:02 PM
techinspector1's Avatar
Wiki Edits: 326
This is another old wive's tale. Stock setups may bang the seal at 0.430" or even less. You have to leave some play in your calculations for a safety margin.
All you guys are brain riddled with the idea that you have to have a ton of valve lift to make power. Not true. For a street motor, choose the intake closing point to match up with the SCR and use a valve lift of 0.400"-0.425", using all the stock L31 pieces including springs, retainers, keepers, seals and rail rockers. Use a socket and small hammer to tap the valve seals down onto the guide. Some of them were not installed correctly and will sit up on the guide, diminishing retainer to seal clearance. For the money you save, you'll never miss the 15-20 hp you might pick up with more lift.
Old 12-15-2011, 01:28 PM
Well not to be rude, but that 15-20hp or so is exactly what I want. My truck has a 4.8L Gen III Vortec V8 in it and it makes 280hp stock, and I plan on doing a full exhaust on it and everything because the original is starting to rot and needs replaced, so I estimate its going to make around 300hp in the end. I want my Camaro to blow the doors off of the truck in terms of performance. And this truck is the fastest thing I've ever owned so I want there to be a power difference big enough for me to notice and make all this V6 to V8 engine swap stuff worth it.
Old 12-15-2011, 01:44 PM
Banned
How much power do you plan on making with your engine? Vortec heads may be the wrong route to be taking.
Old 12-15-2011, 01:45 PM
Wiki Edits: 326
Well not to be rude
No problem here dude, knock yourself out.
Old 12-15-2011, 04:45 PM
I'm not going any other route with heads, I got my set of brand new Vortecs off a crate engine for $200. Can't beat it. I've seen people push 360-370HP from 906 Vortecs and TPI and thats what I'm doing. If I get 325hp then I'll be happy, but the more the merrier!
Old 12-15-2011, 04:49 PM
I do appreciate the help and your opinion though, thanks.
First time Modifying Vortec Heads for Lift. zildjian4life218 Engine 43 02-19-2011 08:56 PM
How to get more lift out of Vortec heads maxpower_454 Engine 3 02-16-2009 09:12 PM
What will I need to do to my Vortec heads to accept this kind of lift? 04SilveradoMykk Engine 13 07-25-2008 02:59 PM
Vortec heads w/solid lift cam...anyone? rbomar Engine 6 08-25-2006 04:42 PM
Vortec Heads / Max Lift? onecoomofo Engine 16 01-27-2004 11:51 AM
