Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Getting to around 396cid using 880 block
  #33 (permalink)
Old 03-25-2013, 05:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Hogg View Post
I do like that 7137 intake, I was looking at its Vortec brother in the past, for use with the Largeport Bowtie Vortecs.
Those heads look like they are serious parts. Do you have personal experience with that company? HAve you used these parts?
This is starting to look like a higher rpm setup now.
Any opinions on converting a 2 bolt block to splayed mains, or would stock 4 bolt mains suffice? Would you take 2 bolt mains to 7000rpm?
Thanks again.
peace
Hog
A stroker crank and 2-bolt caps @ 7000 rpm is an open invitation to cap walk.
To run the rpm a cam in the 250 degree @ 0.050" lift range is going to use, you are going to want all the stiffness you can get. Splayed caps would be a given for me. You might get away w/factory 4-bolt cap arrangement w/good caps and aftermarket fasteners, but the wider register that the splayed caps can give is a real plus IMO.
2-BOLT OEM BLOCK
4-BOLT OEM BLOCK
4-BOLT SPLAYED CAP OEM BLOCK Using Milodon Caps
4-BOLT SPLAYED CAP FULL WIDTH REGISTER BOW TIE BLOCK
