Getting bigger - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2005, 07:38 PM
Getting bigger
I have a 72' c/10 350 350 turbo 3:08 12 bolt. I am acquiring good ole' Moms 75' 454 400 turbo not sure of gear ratio but seems fairly low. Her truck is junk and i want, at least, the engine for my truck. what is it really gonna take to achieve this. My front suspension is dwarfed in comparison. ideas?
Old 09-13-2005, 04:06 PM
Should be a bolt in......
Your 72 could be ordered with a 454.....
Old 09-13-2005, 05:30 PM
Canzus's Avatar
a red wool sock on his dinger
My Brother had a '70 C10 with a 402, the suspension was
the same as my '69 with a 292... Is Moms a 3/4 ton??
Old 09-13-2005, 07:33 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
If you look on the frame rail where the crossmember bolts in you should see a hole in front of where the crossmember is bolted in on either side. I am not sure but I have been told the crossmember needs to be relocated to where that hole is in order for the big block to bolt in. If you look at your frame rails you will see what I am talking about. Ive never had anything but a small block in mine so I dont know for sure...something you may need to be aware of though.
Worth it to put bigger valves in stock seats??? sizemoremk Engine 3 08-13-2005 12:19 AM
water pump using coolant for turbo, Bigger TBI? Sycloned Engine 1 05-22-2004 06:25 AM
Average cost of getting bigger valves in your heads? sb72elcamino350 Engine 7 04-25-2004 04:45 PM
s-10 2.8 vs 3.4 what did they do for the bigger displacement catscan4free Engine 2 01-31-2004 11:59 PM
Bigger Engine Lincoln Engine 4 08-29-2003 04:10 PM
