getting the correct flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2008, 08:20 AM
I have a question on a 1989 fuel injected motor. The engine I own is a 460 block ID (D9TE-AB). It is in an 1989 Econoline E350 with an automatic transmission. I want to put a manual flywheeel on this motor. I think in 1989 the engines were balanced EXTERNALLY which leaves me confused on what manual flywheel I can just bolt on and have the engine correctly balanced. Some have told me a ZERO balanced flywheel will work while others say no.I need to know how to have this engine correctly balanced with a manual flywheel. Thanks for any info.
Old 06-16-2008, 03:33 PM
nitro_baller4692's Avatar
floppers forever
1979 and newer are external 1978 and older are internal.79 and newer will be fine
crank to flywheel mate Keith Gross Engine 1 10-18-2005 03:06 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 07:44 PM
Need help with numbers on flywheel please?? Robbie Transmission - Rearend 2 06-06-2004 12:43 AM
flywheel to convertor holes not lining up??? v8s10 Engine 8 06-01-2003 09:53 PM
STARTER AND FLYWHEEL DOESN'T MATCH UP mrmonte2323 Engine 8 11-19-2002 07:37 PM
