Getting excessive dust/dirt in the paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2009, 07:13 PM
I have a homemade booth in my basement that pulls air in from the outside and blows it out to the outside. I have furnace filters on each fan. The inside of the tent is fairly air tight with all new plastic laid down. I even wear a full white painting suit. My problem is that Im still getting a piece of dirt every 6" or so that I have to wet sand out. I have a little water/oil filter inline on my air hose. But not one of those larger filters that hook up to the output on the compressor. So my question is, could dirt be getting through my gun because of lack of filtration? It's just really annoying every time I paint since the paint lays perfectly flat and I shouldnt even need to wet sand but have to because of the dust/dirt.
Thanks for any suggestions.
j
Old 02-05-2009, 12:03 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You need the larger filter and with the plastic there can be stuff that falls off of it..bits of dirt in the paint can be caused by water in the lines as well as the water drops will react with the paint and leave a "dirt speck"..that may be the issue..Mount the air/water separator as far from the compressor as possible and use metal line between the compressor and air/water separator..Keep the hose as short as reasonable from the wall to the gun..
Place both fans at one end of the booth so they act to blow in to the booth and just a filter at the other end..this acts to pressurize the booth so any dust leaks are blown out rather than sucked in..Keep the air velocity low as fast moving air stirs up any dust.
Just a few ideas on paint booth design..
Sam
Old 02-05-2009, 05:56 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Tell the kids to stop running around upstairs! Seriously
Also, I would ditch the fan blowing in, that just stirs up the dust.
Old 02-05-2009, 05:58 AM
That would make sense. Im using a 25' hose from the compressor and have the filter attached on the line just before my paint gun, but I've notice the last couple times I've painted, no water or anything has collected into the filter. I wonder if the cheap little Harbor Freight filter is already trashed.
Thanks for the input.
Old 02-05-2009, 04:06 PM
Well, i tried painting today and pretty much got the same results. I installed a new filter just before the gun. I guess I have lots of wet sanding in my future.
Thanks for everyones suggestions.
Old 02-05-2009, 07:06 PM
I've got a kobalt inline filter with hard line attached to compressor. Do I still need a water filter or are those compressor filters air/water? Also what I was thinking about to build a paint booth was to cover everything but the floor with plastic and on one side install a good furnace filter in the plastic and then put 2 20" square fans in the 2 garage windows blowing out. This should work right? as in theory it will blow out all the bad air and suck in fresh air.
Old 02-05-2009, 09:41 PM
j
Many times when you have this problem It is caused from the Car having lint on it already
Are you cleaning with Prep ? using a tack cloth and then blowing off the surface before you paint ?
52F1
Old 04-28-2009, 10:10 AM
A dumb one.
A dumb one. What is the 'hard line'? - A filter, type of airline, an anti static line etc?
Thanks G
Old 04-28-2009, 03:00 PM
hard line --iron pipe or riged plastic--streight copper-- you dont want waves or sags in the line -- have it fall slightly toward your water trap-inline filter-
Old 04-29-2009, 02:50 AM
Re Hard Line
Why? Is that to stop particle buildup.
My line runs from ground level to 3m high (over pasage) then back down into booth.Then whats left is coiled and then a Coalescent filter 3m from gun. Booth is self contained small building - air tight, compressor is outdoors. I could relocate the compressor to have it set as a hard line , but what effect does this hardline approach have ?
Thanks G
Old 04-29-2009, 05:42 AM
Wiki Edits: 3
Having a significant amount of "hardline" metal pipe between the compressor and water trap allows the air to cool before it gets to the trap..this allows the water to condense and then the water trap can do its job..i have about 40 feet of metal pipe running overhead and then I have two..yup two water traps in series and then a toilet paper filter after that to pick up any moisture that may be in the lines..
the dirt problem may not be dirt..it may be water as water will combine with the iso's in the paint to make little particles that look like dirt specs in the paint..Minor tech point but a biggie if you are the guy that has to fix it..
Sam
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
"Basics of Basics" Color Matching-Alternates MARTINSR Body - Exterior 2 02-03-2007 06:33 PM
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
