Getting the highbeam bulb to light - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2008, 05:20 PM
Hi Guys,
Help PLEASE! Here's what I've done. I have a 2002 S10. I made a new aluminum dash with all new Auto Meter gauges. Green turn signal bulbs and one blue high beam bulb. I have all my new wiring finished and everything works right except my high beam indicator bulb.I think I'm at my limit of understanding this! I thought I had it because I found the wire by the steering column that lights up when I used my test light when I flashed the high beams. I hooked it up but when I turn my high beams on it just flashes for a split second. It's like I'm flashing my brights to oncoming traffic.It just flashes when I flash it. Hope you are with me here!Can I splice into the high beam bulb at the headlight? Do both high beam wires need to be spliced together then to the indicator bulb and then ground the other side of the bulb?Give me some ideas guys!! Man DOC was the man. I know we all miss him!! Thanks in advance guys!!!
Thom
Old 05-14-2008, 05:28 PM
poncho62's Avatar
Wiki Edits: 5
I think you just have it hooked to the wrong wire. I figure when you pull on the lever, it sends a signal to the relay to the high beams momentarily...That must be the wire you are hooked to. There must be another wire there for the light.....I take it you didn't label it when you took the old dash out?
Doc would probably had a wiring diagram for this......maybe someone else does.
Old 05-14-2008, 07:42 PM
Hi Poncha62,
Yea you are right! I didn't label it!! I'll try somemore wires, or like you said someone might have a wire color or a diagram. Thanks for your reply.
Thom
Old 05-14-2008, 08:09 PM
No High Beam Indicator
You might try getting a book on your S10 from some place like auto zone and checking out the wiring diagrams for the steering column. That is most likely where the high beam indicator wire originates from.
Old 05-14-2008, 10:12 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Originally Posted by tommer2
Hi Guys,
Thom
Yes you could do that easily and you would only need it on one hi beam bulb. What you have though of is a fine work around and will not have any bad effect on the circuit as a whole, you are just picking up a signal in the circuit at a different location.
Better yet locate the wire for you high beams before it goes out the firewall. It will take a try or two, I think already you understand the idea as a whole, but here is some detail.
At the main plug going out the firewall you should have two wires for your headlights , hi & low . With everything off no key pull the light switch on find the low side and then turn on the hi side and find that wire just put a splice in that wire.
You just might stumble across the the original connection in the process of working the work around.. Can not remember for sure but I do not think the hi beam indicator light for hi beams is through the column, a signal for the relay would run down the column and out to a relay ( hi beam) and the connection would be on the closed side of the relay contact.
Old 05-14-2008, 11:23 PM
Hi Pepi,
That is a GREAT answer. I'll do it tomorrow!!! Thanks again!!
Old 05-15-2008, 07:20 AM
pepi's Avatar
fat fingered ................
Old 05-15-2008, 07:25 AM
pepi's Avatar
My pleasure glad I could be of some help ......... it is always something.
But that is the fun of it all..
Old 05-15-2008, 09:29 PM
Hi Again Pepi,
You were right on!! Did what you said, found the wire and spliced it. PRESTO highbeam indicator lights!!! Thanks for you other guys that chimed in!! This fourm is the BOMB!
Thom
wiring up a highbeam indicator bulb tommer2 Electrical 1 05-10-2008 03:00 PM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 11:02 PM
How many Forum members.............. Stitch Hotrodders' Lounge 29 03-11-2004 08:31 AM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 04:39 AM
a little humor to get through the evening antirice Hotrodders' Lounge 7 08-28-2003 09:36 AM
