Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Getting at interior rust
Old 11-17-2002, 02:24 AM
Wmarden Wmarden is offline
Last journal entry: Some pics
Most of my interior problem is the roof and sail panels. Not bad, just surface rust, but I don't want it to go any further.
I am going to have to patch the passenger floor(I am going with a new front floor section and some patching in the back), driver's floor near the pedals, both rear quarters below the body line, the driver's side fender(a little hole, but still needs to be patched), the rear glass area, and the trunk floor(but I already have plans on how to fix that up).
It sounds like a lot, but really only the passenger front section and the trunk floor need much replaced. Alot of the rear quarters is more to prevent it from spreading as it has not rusted through much. Most of the problem is on the drivers side of the trunk where the rear glass filler panel rusted out. I am looking at maybe 200-300 dollars in sheet metal from year one. So it could be alot worse.
[ November 17, 2002: Message edited by: Wmarden ]</p>
