Getting a Jeep YJ speedo to work with conversion.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2011, 08:04 PM
Is there a way to get the factory Jeep speedo to work with the GM VSS. Most of what I have found has said that I have to change the rear half of the Jeep transfer case with the GM case. Is there an easier way?
Old 02-02-2011, 04:42 AM
cal1320's Avatar
What year YJ? Is speedo cable or electronic? Are you using a SYE on the transfer case? If so , what brand / style? JB conversions makes a Super Short SYE that may be compatible with the GM VSS.
Give some more info.
Old 02-02-2011, 12:35 PM
cont...
Sorry. Its a 93 yj factory electronic speedo and im not running a sye. I thought of going that route but pricey. Is there something electronically that can be changed or modified?
Electronic Speedo doesn't work chazman67 Electrical 0 10-19-2008 03:14 PM
t-5 speedo conversion jammesallen Transmission - Rearend 3 03-30-2008 10:22 AM
speedo conversion timberjack Transmission - Rearend 1 01-19-2008 11:24 AM
Speedo Conversion birdman891 Electrical 3 04-07-2005 05:11 PM
speedo conversion....?? molevolent_creations Transmission - Rearend 2 01-14-2004 06:52 AM
