Getting a mirror finish in polyurethane - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2014, 03:40 PM
chief36chevy's Avatar
Last journal entry: Hood holder/horn mount
Ok so Iím finishing the wood boards in my pickup bed.
I am using Minwax Helmsman Spar Urethane.
My problem is I keep getting brush lines in the finish. I am using a paint brush that said it was for a mirror finish.
Any thoughts?
Old 06-29-2014, 05:08 PM
TucsonJay's Avatar
My first thought is to add a little slow reducer, so the paint can flow out some after it is brushed on. If it is too dry, or you keep brushing it as it dries, it might flash before it "lays down".
Old 06-29-2014, 05:42 PM
As was mentioned , thin it just a bit , I never use a brush , instead I use a piece of cotton " cheescloth" , in a pinch just about any clean , soft cotton cloth will work , just fold it up & then grip it so it looks kinda like a ball, dip the ball in the varnish & spread it out. the varnish you're using is "self leveling" so you have to apply enough to make it flow , don't overwork it or you'll get marks. I've been building cabinets & finishing wood this way for about 40 years , my grandpa taught me some tricks...
dave
Old 06-30-2014, 11:07 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
the more you slow it down, the better it will flow.
Some even add retarder.
Old 07-04-2014, 04:49 PM
mitmaks's Avatar
Last journal entry: Grille
you can spray it out to eliminate brushmarks. Once it dries you can wetsand and buff it out just like you would with automotive clear coat, just make sure you put enough material on there to compensate for sanding.
Old 07-11-2014, 07:12 PM
Thanks for all the advice.
I waited for a few days for the urethane to dry so that I could sand it. I started with a DA with 120 grit and followed with a long block with 120 then 220.
I then reduced the urethane by 10% with mineral spirits and spraied them with a HVLP gun and it came out much better. I figure that I will wait a few days and block it with 320 and respray it untili have enough built up so that I can wet sand and buff.
Old 07-13-2014, 09:04 PM
mitmaks's Avatar
120 grit is too course, you could start with 320 dry, put another 2-3 coats and wetsand that starting with 400 or 600 and finishing all the way to 3000 if you wanted to. Just dont take off too much with rough grit, otherwise you got the right idea.
The Following User Says Thank You to mitmaks For This Useful Post:
chief36chevy (07-14-2014)
Old 07-16-2014, 09:13 PM
Why would you start with something as harsh as 120 grit? I'd say 400 would be as low as you need to go, and just take off smaller layers. I want to see some pics when it's done!
Old 07-17-2014, 07:06 AM
Wiki Edits: 31
I would only use Epifhanes spar varnish.. Any wooden boat builder/ restorer, knows quality varnish counts
Old 07-17-2014, 11:27 AM
ogre's Avatar
the 'Duracell Project'
don't use a da sander either, a soft block or sand paper on a thin rubber pad will be good
i'd hit it lightly with dry 320 sanding with the grain and then add a few more coats of poly then 320 and 400
hand sanding with the grain and 400 will never show scratches, buff or wax to get a mirror finish
Old 07-17-2014, 03:40 PM
Clear the air
Please let me clear some stuff up. I refer you to my original post. I did say that I started with a brush which gave me brush marks. I used the 120 to remove the brush marks and then went to 220 and then 320 before I tried to spray.
Since then I am getting much better results.
What type of polish would you use on Minwax Helmsman Spar Urethane?
Old 07-18-2014, 04:27 AM
jcclark's Avatar
The Penny Pincher
After all that trouble, you would have been much
better off using a automotive urethane clear coat.
Old 07-18-2014, 04:09 PM
After 60+ years of life lessons (OJT) I am using most and learning some other new tricks along the way. This is my first hot rod project. I am learning a lot usually after the fact. I ran across this web site and I have used the heck out of it. The people are very helpful and once in a while I have been able to help someone out. I did not know about automotive urethane clear coat.
But thanks anyway.
Old 07-20-2014, 02:55 PM
Old Fool's Avatar
I suggest using SPI Universal Clear next time, lots of guys have done that and had fantastic results.
urethane and polyurethane dwhitt Body - Exterior 24 12-28-2012 08:04 AM
Does anyone here end with a mirror smooth (not a hint of gun texture) finish? 777funk Body - Exterior 12 07-14-2011 07:37 AM
Aluminum compents including cast alumunim can be detail polished to a mirror finish! Elite Metal Finishin Introduce Yourself 17 04-25-2011 09:34 PM
How to I prepare an acrylic enamel finish for a bc/cc finish? klingfilm Body - Exterior 2 10-12-2009 12:50 PM
Painting polyurethane WakBordr7387 Interior 9 07-10-2005 08:44 AM
