Getting more preasure to my paint gun
Hi,
Sorry if this is the wrong section; I'm not sure if this is a tool question or a body section (since it's a tool, but a body specific tool I'm asking about). K, so I sprayed my epoxy, high build, and sealer, and now i got to the base coat. I've been having run problems all along, but have chalked it up to inexperience. Now my base looks bad - I have orange peel AND runs. I've read that orange peel control is fluid adjustment, and run control is pressure adjustment over at the SPI site (more pressure = less runs if I read correctly). If I dial back the fluid to get rid of my runs, I get orange peel. If I get rid of the peel it runs. I can only get 15 PSI at the gun during a full trigger pull. It starts plenty high, like 90 PSI on my at-the-gun regulator, but drops like mad with the trigger open, and settles around 15. The compressor tank is at 120. I have, starting at the tank, a ball valve to shut off the air, a regulator with gauge, a desiccant dryer, and then a female coupler. The 3/8" hose has a male coupler. At the other end of the hose is a high-flow female. The gun has a high flow male, a regulator/pressure gauge, one of those pumpkin 'last chance' water/oil filters, and then the gun itself. Does anything stand out? Where would you start looking to get more preasure at your gun? And I'm clearing over this - when I sanded my black primer, it turned grey, but got nice and black and glossy when I put some W&G remover on it. Will the base be the same - go grey when I sand, but blacken up when I get the clear on? Thanks for any advice! Oh, it's a 3.5 HP 60 gallon compressor, and a Shapre Finex FX300 HVLP in case that helps. |
Do you have a reulator at the gun? You must remember that for every foot of hose you have you will lose 2 lbs of pressure per foot. So if you have a 50ft hose you can lose 10 lbs of pressure at the gun. I have a regulator at my gun so when I pull the trigger I can regulate exactly what pressure is coming out. That way you can keep the pressure at the outlet on the wall at 120 and regulate down to the 40-45 lbs or whatever the pressure needs to be for what you are shooting.
Look for HVLP-specific airline fittings too. They have twice the bore diameter and will NOT be a restriction.
Russ |
| "Basic of Basics" Can I use "rattle can" paint on my car? | Centerline | Body - Exterior | 33 | 07-08-2011 12:33 PM |
| No preasure in paint gun | eighty-one | Body - Exterior | 7 | 05-04-2009 08:10 AM |
| More on Orange Peel | KarKen | Body - Exterior | 36 | 03-22-2009 02:18 PM |
| I'm buying a new paint gun | speedaire | Body - Exterior | 2 | 07-21-2007 10:15 PM |
| Paint gun for Paint and Primer ??? | 62440 | Body - Exterior | 2 | 06-22-2007 10:53 PM |
