Getting Mounted - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2003, 06:49 PM
Arrow Getting Mounted
i was looking around at the local speed shop, and saw a few thing of intrest. these polyurethane engine mounts, are they worth the cost? also would the beworht it in the suspention? im more conserned witht he months though. also i want to know if my idea of drawing a 2 port off the manifold vac. one line going to the trans modulater, and the other to a vac canister to use my power breaks.
Old 01-15-2003, 07:42 AM
Post
common guys give some ideas here, are they worht the money?
Old 01-15-2003, 08:02 AM
Post
they are worth the money they are design to last longer then the OEM type mounts. I have not use the motor mounts yet but have use the suspension sets and so far the have outlasted the OEM parts by ten years and still going strong
Old 01-15-2003, 08:07 AM
Frisco's Avatar
Glad To Be Here
Post
In my opinion; for a street car, "No". They offer the same warranty as the stock replacement but at almost twice the cost. The motormounts would probably be good in a high torque application. The suspension parts would be better for a road race or off the road vehicle.
Old 01-15-2003, 08:10 AM
Frisco's Avatar
Glad To Be Here
Post
[quote]Originally posted by Camaro76:
<strong>i want to know if my idea of drawing a 2 port off the manifold vac. one line going to the trans modulater, and the other to a vac canister to use my power breaks.</strong><hr></blockquote>
This will work fine IF you have enough manifold vacuum. Most carbs have a connection at their base for the power brakes.
Old 01-15-2003, 08:17 AM
Post
[quote]This will work fine IF you have enough manifold vacuum. Most carbs have a connection at their base for the power brakes.
<hr></blockquote>
what is enough?
Old 01-15-2003, 08:26 AM
bonuts's Avatar
Got Ouzo for touzo
Post
Sounded to me like a topic from "SLANT SIX", and sorry there I don't know if they're worth the cash.
bonuts
Old 01-15-2003, 02:54 PM
Frisco's Avatar
Glad To Be Here
Post
<strong>
what is enough?</strong><hr></blockquote>
14" or more at idle in gear should work your stock power brake booster fine.
