getting a new garage - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2003, 04:47 PM
crshrmn3's Avatar
Well I finally put a deposit down for a new 30' x 40' garage. I opted to go with a steel building. It will have a 14' height in the center and a little over 8' at the walls. Hoping to have it paid for and delivered in time to put it up early next summer. Perhaps then I would finally be able to retire my old piece of plywood and get to work in a halfway decent environment. Guess the new furnace and kitchen remodel will be pushed off for another year.
Old 11-11-2003, 04:51 PM
Moby302's Avatar
Psychotic
Yeah, garage first, who needs food and warmth when you've got a decent garage to work in. I totally agree with you.
Old 11-11-2003, 04:52 PM
Kevin45's Avatar
Just one of the guys
Congrats on the new garage. No feeling quite like it!! Now comes all the planning...where to put the bench, fridge, tv, cabinets, lighting, etc, etc, etc. Plan on losing lots of sleep over this aquisition.
Kevin
Old 11-11-2003, 05:01 PM
k2mooch's Avatar
SmoocH and I are looking at houses and we've decided that I'm going to need to build my own shop also. How hard would it be to just pour a concrete slab, stack up some cinder blocks, insulate, and cap it with a roof? Only need to house one project car at a time. Any ideas on total cost? I just wanna know how much to save up for. Thanks.
MoocH
Old 11-11-2003, 05:38 PM
Kevin45's Avatar
You'll have to check with local building codes to be able to come up with a half way decent price. Also prices vary from area to area. Around here you have to have a footer 3'deep and the block has to be one block above ground level. To lay block a mason gets $1.25/block regular and $1.75/termite block. You can buy garage kits for anywhere from a shed to a three car garage. Usually the lumber companies advertise these as standard packages. A 2 car garage (24x24) deluxe that includes overhangs and vinyl siding goes for around $2400-$3000 not including foundation. If you can build it yourself or have a bunch of buds that knows what they are doing will save quite a bit. Doing it that way with foundation and all will run around $5000. That does not include any insulation etc. Just a basic garage. to have someone do it would probably cost double that and maybe more. It pays to shop around and find who can do what as far as digging footers, laying block, pouring concrete, and anything you can do yourself saves. Also, if is attached to a house, saves one wall and one foundation wall from being put up, which is a savings. I built a 28'x36' w/6' overhangs in the front and side, vinyl siding, finished off on the inside and had $5000 in just the driveway, floor and foundation and again that much in the garage. I built the garage myself (Weimer and I). If I had hired contractors I would have had $25-30,000 in it.
Kevin
