getting a new vin sticker - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2012, 05:18 AM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
I should have taped around it, but i picked at the edge and it came off easier than i thought so i pulled it but of course it doesn't exactly stick back on. Rookie mistake but what are my options? Its on a 92 bronco...
Old 09-25-2012, 06:31 AM
novafreek6872's Avatar
Nova Guru
If the sticker is still intact and readable, why couldn't you use spray adhesive on the back and stick it back on?
Andy
Old 09-25-2012, 09:31 AM
Mach1460's Avatar
That's a great point, never really crossed my mind. There are a few spots where small pays came off but its definitely still readable. Worth a shot though thanks
Old 09-25-2012, 10:25 AM
Before you mess yours up take a good close up photo of it. You can send that photo to Signsolutions at 952-229-5411 and they will make you a new sticker. We use them all the time being the manufacturers of the cars either don't supply those stickers or they take a ridiculously long time to get them to you. Signsolutions gets them to us in days.
Old 09-25-2012, 06:50 PM
I assume you are talking about the sticker on the drivers door?
or are you messing around with the vin tag on the dash?
Old 09-26-2012, 08:32 AM
Mach1460's Avatar
Drivers door sticker, I'll try sign solutions. Thanks guys
Old 09-26-2012, 03:23 PM
hp246's Avatar
The sticker on the door is not the "VIN sticker." It is most likely a trim tag. The VIN needs to be permanently affixed to the vehicle. You can probably find that tag re-popped by someone. A VIN tag is a whole different matter. When you start messing with a VIN tag, you can get into a whole lot of problems.
Old 09-27-2012, 04:31 AM
Mach1460's Avatar
Its not the vin tag, sorry for the misinterpretation, its the sticker in the door jamb and has the vin number on it, it also has the trim codes axle ratios and so on . I'll post a pic tonight
Old 09-27-2012, 07:56 AM
That is what I was referring too with my suggestions for SignSolutions. It's commonly called the VIN sticker because the VIN is on it along with the other info. And in fact on many cars there is ZERO info on it other than the VIN and the Production date.
Old 09-27-2012, 08:23 AM
Wiki Edits: 31
Yep, GM trucks have the other info as codes in the glove box. Door stickers show tire size, vin and production date along side the GVRW.. But on a Ford of that year, has everything from the axle code to the trim and paint codes to the interior color
Old 09-27-2012, 12:31 PM
Mach1460's Avatar
I called that number and got a recording, something like Andrew J inc (hard to understand the recording) Is that the right place or number?
Old 09-27-2012, 11:53 PM
Hmm, I'll check tomorrow. I got that number right out of our directory but I could have made a mistake.
GM is proud of this little sticker! MARTINSR Hotrodders' Lounge 13 09-24-2010 12:51 PM
I just got this really cool sticker! redlightning Off-Topic 2 10-15-2008 03:15 PM
Sticker shock...again! 302 Z28 Body - Exterior 12 04-14-2006 08:21 AM
STICKER SHOCK!! dinger Suspension - Brakes - Steering 3 05-16-2002 07:15 AM
