getting overspray off clearcoat - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2009, 08:11 PM
I painted my car with urethane base coat clear coat.I had a bad run in the door.So I masked with paper on the panels around the door.I now have clearcoat overspray all over the rest of the car.What can I do to get it off.It has been about a week so it it is dry. Thanks proge
Old 06-06-2009, 08:24 PM
The best way to remove it is not to get it on there to begin with. But, I think you've figured that much already and will invest in papering correctly next time without taking a costly short cut.
If you haven't already sanded and buffed prior to your misadventure go ahead and do so. It should be alright afterwards.
If you did then repeat the same. Caution though. You may have to reclear if you go through.
Old 06-06-2009, 08:56 PM
001mustang's Avatar
Sometimes overspray can be be removed with a clay bar system available at most part stores; depends on how wet overspray was when it landed on car.
Color sanding and buffing will definitely remove overspray but will take awhile and you must be very careful not to cut through clear.
I wetsanded through my clearcoat!! (and I have lots of tree sap!) fiscus Body - Exterior 4 06-18-2010 11:13 PM
decided to clearcoat it proge Body - Exterior 2 03-06-2009 06:26 AM
removing primer overspray on clearcoat tgennings Body - Exterior 4 03-20-2007 05:15 PM
Newbie Here with clearcoat question Damien89 Body - Exterior 13 01-14-2007 04:15 PM
Can I put clearcoat on top of a lacquer paint viperACR Body - Exterior 10 06-18-2004 10:44 AM
