Getting ready for a carb to tbi swap! - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-09-2013, 06:50 AM
I've posted about my 1985 S-15 that had a 2.8l originally, which I replaced with a '93 3.4l.
I then went to an Edelbrock manifold and a Holley 4 barrel 390 cfm carb.
Since I've had the truck running, I've not been able to get the thing to run well consistently. Seems like once a week, I've got to fix something with the carburetor. It was like new when I got it and did a rebuild with Holley's kit.
What I should have done, but did not know it at the time, that I could have gone straight to a tbi setup.
In any case, I have most of the parts to do the tbi install and am thinking of using the Edelbrock intake I have on there now, BUT, I have a question about it.
The portion of the Edelborck intake for the 4 barrel is the picture below. The throttle body I am using is the model 220 and has two bores/two injectors.
Would there be any benefit to removing that center partition in this part?
The only issue I can think of that might be a problem would be if one of the injectors went bad, then one side or the other of the engine would not get any gas, creating a lean condition, then probably driving the other injector to richen the mixture for the opposite side even more, probably resulting in the fouling of the plugs.
Thoughts?
Old 02-27-2013, 10:58 AM
bigdog7373's Avatar
Of course it's fast
Do not remove the center. It's made that way for a reason. Only reason you'd want it open is if you're running super high rpm.
Old 02-27-2013, 02:05 PM
Thanks for the reply. I did not modify that part as I had realized that I still needed a spacer for the throttle body anyway.
Old 02-27-2013, 02:17 PM
bigdog7373's Avatar
Of course it's fast
Cool. Just make sure you get the spacer with the separation too. You should keep the rignt and left side separate or it will not have that low end torque you need.
Old 03-04-2013, 10:17 AM
Everything is HAMMER!
Sounds like some bad luck with your carb. My camaro had a holley and after a rebuild and a little tuning it ran like a champ and never required much attention, same thing for the holley on my buddy's 302 v8 ranger.
However, if you ever feel like doing any tuning on the tbi you should really look into the EBL flash system, the options of what you can tune are astounding and it has a self learn(tunes while you drive) capability as well. You will never look back to carbs once you figure out efi tuning.
Good luck with the swap!
Old 03-04-2013, 02:38 PM
I got the TBI install finished up on Saturday morning and spent the day getting little things sorted out.
She is running and pretty well at that after sorting out a lean issue.
The custom tuning is one of the reasons that I wanted to do this swap.
Here is a short video of the engine running:
Recent Modern Electronic Engines posts with photos
94 350 tbi to carb swap. jerryvarnell Engine 7 11-19-2011 11:27 AM
TBI to carb swap eatonde Engine 20 09-09-2008 11:01 AM
Carb to TBI Swap? mrevil General Rodding Tech 2 03-26-2005 09:38 AM
Carb to TBi Swap Project Junorr Introduce Yourself 7 09-06-2004 03:27 PM
Tbi To Carb Swap strracer7 Engine 5 08-05-2004 12:13 AM
