getting ready to paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2005, 05:29 PM
hotrod66_57's Avatar
Last journal entry: dolly
hi,
i recently purchased a 1957 Ford F100. after a few months of tolerating a less than perfect "green" paint job i decided that new paint was in order. my question is what i should do to prepare the truck for a pro paint shop. i want to do all the prep work my self and have the shop spray the paint, that's all. i know that the truck could have at least 2 layers of paint on it currently. what i need to know is if i need to strip it down to metal and then fill in the dents/imperfections or if just sanding down the bad spots would help. i would also like to know, if all of the previous paint needs to be stripped, what method should be used, abrasive, chemical, etc. thank you very much.
hotrod66_57
Old 02-02-2005, 09:12 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Wow, this topic has bee beat to death every conceivable way. Do a search on the board and you will find every possible opinion and be able to make an intelligent choice on which way to go.
Old 02-02-2005, 10:41 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
That, and most quality shops WON'T guarantee the job unless THEY do the prep work.
Old 02-08-2005, 01:15 AM
coop_01's Avatar
New Member
If you havent searched the fourm for the cure for this its true alot of body shops dont care if you prep it they will go over it again
& charge you for it & you will just have aching elbos & busted up knuckles from the d/a sander if you havent done prep work before theres more to it than what you think
but if you want i sugest you get a roll of 220 to smooth it out as much as posable & break through some of those layers of paint & finnish up with some 180
« Fillers | Top Chops »
