getting real paint on my camaro - Page 12 - Hot Rod Forum : Hotrodders Bulletin Board
  #166 (permalink)
Old 07-10-2013, 11:55 AM
Faith - Respect - Trust
By the looks of the vehicle, you seem to have a fairly straight car that requires a minimal of body work, that's great! If I can offer a little advice, your at the point now where you now need to focus and concentrate on getting one panel prepped at a time.
A fairly common mistake is to jump from one panel to the next without completely finishing any one panel and often (I'm not saying in your case) the car takes a lot longer than it needs to to get done. Much like blocking a vehicle, I try and focus on one panel at a time (wherever possible) especially when it comes to final sanding/blocking...it's amazing how much more you can get done.
Ray
  #167 (permalink)
Old 07-10-2013, 01:59 PM
Project89's Avatar
Ray
thanks and yes i started jumping around a lil bit , but thats due to my back injury sometimes i just need to move and stand up or change positions.
so far ive gotem one qaurter fully preped , and almost done on the other , just had to take a break as theres no shade left at all and its just to dam hot out right now
prolly start back up on it around 5 ish
and yes the da was useless with the compressor i have
  #168 (permalink)
Old 07-10-2013, 02:36 PM
cyclopsblown34's Avatar
Colorsanding painter
By my experience with epoxy on bare metal, tech sheets say 80 grit scratches are as fine as you want to go.
  #169 (permalink)
Old 07-10-2013, 02:45 PM
Project89's Avatar
thanks thats what i thought was said before just wanted to make sure , ive been block sanding the panels with 80 grit paper , think im actually down to my last sheet , have to dblo check and so i can pick up a new pack of paper before the stores close.
my town sucks by 6pm everything is closed down, hell u cant even get a pizza after 8pm , by 8:30 the town is a total ghost town lol
last question is about the spot putty/glaze i got for some small lil dings what is the thickest amount u should do 1/16th etc just want to make sure i use body filler in those minor dings instead fo spot putty if they are to deep
  #170 (permalink)
Old 07-10-2013, 10:13 PM
Project89's Avatar
Originally Posted by deadbodyman View Post
Dont forget.......Safty first....
U know I saw this post yesterday and picked up a pack of dust masks. Guess were they sat all day today.........in my truck gee good place for them
Just looked at myself in the mirror and I'm grey head to toe.
Well can't be any worse hen the cigarets I smoke.
Anyways. I got some pics were I'm stopping for the night. Prolly around 90% ready for primer. Got a lil bit of paint to still sand a and some body filler work. But my friend who is spraying the car told me not to worry about it and when I get the car there friday he will help me finish and we will prime it Saturday
Ill upload some Pics in a bit I'm using my phone right now and for some reason I can't upload from it
And thanks again for all the help specially u 69widetrack if it wasn't for u guys I'd have been screwing this up big time.
Can't wait to see the car with even just the black primer on it
  #171 (permalink)
Old 07-10-2013, 10:23 PM
make sure those dust masks are N or P95, otherwise they aren't doing much for you.
  #172 (permalink)
Old 07-11-2013, 05:56 AM
RalphL's Avatar
I'm also a hobbyist painter. I have a 1972 Z-28 RS that I painted last year, and also a 1969 Corvette convertible that I'm restoring.
The third gen Camaros appear to be gaining in popularity. In the past year, I've painted three of these for my buds: 1985 Z-28 copper/gold; 1984 Z-28 charcoal grey; and a 1986 Camaro total color change from copper to torch red - we also transferred some parts (ground effects, rear hatch) from a 1992 IROC!... and get this, I'm helping yet another friend with his basket-case 1986 Z-28... currently in rattle-can black. He's been down on his luck, so we're gonna paint his car jet black....
I've shot single stage and bc/cc, and like many others definitely prefer bc/cc. The primary reason is the level of fix-ability you can obtain during the cutting and buffing stage. I don't have access to a paint booth with a down-draft system, etc and I do get dust in the clear - and have also had a mosquito or two find its way into the stuff - ugh! No worries, these flaws can usually be corrected using the bc/cc...
I've been using SPI epoxy and urethane primers, and also SPI universal clear coats. It's hands-down excellent stuff. For the basecoat, I've used PPG Shopline brand. Yes, it's PPG's economy grade paint; however, I find it to be just fine. A properly prepped surface, utilizing good technique (flash times, tack rag between coats, etc) - and above all, PATIENCE will serve you well.
Good luck to you... I've been reading your posts and can appreciate all the info you've been gathering and great advice you've obtained. Be patient, you'll do great (and save $$ too!)
I've attached a pic of the 1986 torch red 'Frankenstein' Camaro project we completed last May. If you're interested, I'll see if I can find a pic of our current 'basket-case' black Camaro project.
Ralph
Name:	1986 Camaro Project.jpg
  #173 (permalink)
Old 07-11-2013, 06:08 AM
deadbodyman's Avatar
Wiki Edits: 11
Your not too crazy ....I had replaced a rocker,bottom pillar and now the 1/4 ...I opened up a can of worms...I stripped mine replaced the pins and bushings (rebuilt the hinges) and at the moment its in epoxy primer and sitting until I get some free time at the shop..One thing I screwed up was I primed it when it was 50 degrees and the primer isnt sticking very well so I have to scrape it all off and reprime it...THAT sucks ...
  #174 (permalink)
Old 07-13-2013, 11:39 AM
Project89's Avatar
ok so primer got pushed off for possibly another 2-3 weeks maybe( as of right now he may call me today and tell me to bring it over still )
if the car is going to be sitting for 2-3 weeks is there anything i can spray on the car to protect the bare metal ? i do not have a garage or shed etc to put the car in to keep the rain off it
  #175 (permalink)
Old 07-13-2013, 09:04 PM
Project89's Avatar
car has to sit is there anything i can do to protect the bare metal for now?
  #176 (permalink)
Old 07-14-2013, 07:36 PM
If it were me I'd wipe it down with wax and grease remover (I've had flash rust in the shape of my hand/finger prints before), throw a tarp over it, and DA any flash rust off when it's ready to prime.
Some would tell you to put Ospho on but I've no experience with it.
  #177 (permalink)
Old 07-15-2013, 05:53 AM
Wiki Edits: 11
You DONT want to put Ospho on it if theres any filler on it ,the filler will suck it up like a sponge and give you all kinds of grief later...why not just prime it yourself ? I think Lizer may be right just throw a tarp on it and pray..
  #178 (permalink)
Old 07-15-2013, 08:02 AM
Project89's Avatar
i dont have a compressor or place to do it myself, as u can see i did all this in my apt complex parking lot. he wants to prime the car for me this comming saturday. im just going to leave it as is and da it real fast on friday and take it over to his farm
  #179 (permalink)
Old 07-15-2013, 08:04 AM
RalphL's Avatar
I agree with the suggestion to use a tarp (or car cover). You'll need to prep the surfaces for primer again anyway, so you could hit any flash rust at that time.
  #180 (permalink)
Old 07-15-2013, 08:40 AM
RalphL's Avatar
That should be fine. For the 'basket-case' 1986 Camaro we're working on - the owner had sanded the roof to bare metal all last week. He lives in a townhouse complex with no garage- and it rained in Maryland/DC all week. When he came by yesterday, we hit the flash rust with the DA with 80 grit, cleaned and prepped the surfaces, and sprayed two coats of epoxy primer.... no problems.
ID:	75706   Click image for larger version
1972 Camaro - first real restor attempt Zanzahl Body - Exterior 7 03-28-2007 10:41 AM
New Paint, Clear Scratches real easy?? syclone477 Body - Exterior 11 03-20-2005 08:08 PM
real dual ex pipes headrs back 86 camaro methuenyankee General Rodding Tech 5 03-17-2003 10:05 PM
560/15's REAL pics of REAL Car! DragLinkscc Hotrodders' Lounge 7 10-21-2002 05:54 PM
1989 camaro (sorry i know its not exactly real old) oldcarguy85 Hotrodders' Lounge 2 01-28-2002 06:41 PM
