ok so im preping to get my camaro painted here very soon
i have one of the summit single stage kits here for the paint ) black cherry pearl) , this is the kit http://www.summitracing.com/parts/sum-csumup317/overview/
i have some body work to do on the car
#1 fix 2 drilled holes in the rear decklid
#2 fix crease in the passenger side door .......
normally i would replace the door but the doors/hinges on this car are perfect, no sag/no rattles and i can close the door with 2 fingers. very very rare on a 3rd generation camaro. due to this i dont want to replace the damaged door and have to deal with hinge pin kits and all that goes with it
the damage is not bad but will need some body filler to get stright again
#3 fix minor dent on driverside rear quarter panel, this will also need some bodyfiller to be made stright again
#4 fix a few minor dime to penny sized dents
my biggest thing is im unsure what primer to use on the car since it has plastic bumper covers
with the exception of the roof the rest of the car can be scuffed and painted , the roof however has to be taken down to bare metal
should i be using an epxoy primer on the whole car ,or epoxy on roof and bumper covers only, then a standard or etching primer on the rest of the car ?
