Getting rid of filler - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2011, 09:21 PM
Last journal entry: I HATE BONDO
Does anyone have an effective way of removing well established filler. Someone in the past decided that they'd apply liberal amounts of filler to the rear panel. I'd say at least an eighth of an inch thick.
I worked all night on just a couple areas. Went through about ten 80 grit sanding discs. I know there needs to be a better way to remove all this filler. I want to get back down to the bare metal since it's solid.
Old 09-13-2011, 11:26 PM
dinger's Avatar
Use a 9 inch grinder, get to the metal or close to it, don't burn the metal. If you're uncertain of doing it right, cut through most of it and then use a da with 40 grit.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 09-21-2011, 10:42 AM
Roadsire's Avatar
Last journal entry: Dash mods
Old filler removal
I used a heavy twisted knotted wire wheel on my grinder and it worked well and doesn't hurt the metal behind it
Old 09-21-2011, 01:50 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Yea, what he said!
Old 09-22-2011, 12:40 AM
Ditto. I use it on a drill though, works just fine!
Old 09-22-2011, 10:27 AM
36 grit fibre disc on a grinder like these
http://www.toolstation.com/shop/Powe.../sd1790/p38318
then finish off with a D/A
Old 09-23-2011, 12:13 PM
41SUPERCOUPE's Avatar
<Coupe there it is!
Last journal entry: 41 Chevy Special Deluxe Coupe
Wire wheel on a drill or grinder is my vote, it whisks it away and is less dusty than sanding.
Old 09-23-2011, 04:54 PM
I use a propane torch and a putty knife. Makes for a fast removal and no dust. The old filler will ignight so be careful and take you time.
Filler over epoxy or Epoxy over filler? Here is some good info satexasf150 Body - Exterior 78 10-16-2011 09:35 AM
What filler? guitargoalie Body - Exterior 4 09-10-2009 10:52 AM
Old Filler Gearhead forever Body - Exterior 3 08-28-2006 04:51 AM
before filler?? wisch79 Body - Exterior 1 03-28-2006 06:52 PM
What Filler Should I Use markl Body - Exterior 5 11-06-2005 01:18 PM
