Getting rid of the vent window? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2008, 08:43 PM
I need glass for the doors on my 41 plymouth coupe but I want to get rid of the vent window and put in a 1 piece glass. How hard of a job is it?. Can I just take the vent stuff out and get a piece of glass cut to fit and use the same lifting mechanism? I've been on this project off and on for 7-8 years now and getting back into it so I can have it running this summer. Will be posting pics when I find a little EXTRA time. Thanks for any help!
Old 02-17-2008, 09:50 PM
Wiki Edits: 27
windows
go to the bone yard and check out cars that don;t have vent windows ... usually the channels will have to be changed in the front and the glass guides might have to be modified If not done right the glass will rock and not raise evenly ...also the door upper weatherstrips are different I had door glass amd mechanisms for a while when I was an engineer at Ford...
Old 02-19-2008, 01:06 PM
Dragon J's Avatar
Last journal entry: Harley/Fire
I removed the vents in my Henry J- simple job- just unbolt, remove the bracing for the vent in the door, cut glass to fit and use aftermarket channel and electric window motors. Make sure you don't have a bend in the door so the glass can be straight. You may have to modify the inside of the window surround to accept the channel. I went pillarless in the J and modified the body to accept the gasket.
Window channels and removing vent window Jackyl Interior 11 10-10-2007 07:01 AM
vent window removal codeman Hotrodding Basics 9 03-12-2007 08:12 AM
Adjusting Vent Window on 1939 GM Body JohnTN Interior 1 09-30-2006 09:25 AM
Removing vent window on '58? Nanook Body - Exterior 3 01-09-2005 06:06 PM
72 chevelle vent window parts? 73chevyhelp Body - Exterior 2 04-07-2004 03:55 PM
