Getting the steering mocked up - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2009, 10:02 PM
I just ordered some steering parts for my 48 chev sedan. It has a mustang rack and I am using the stock seat. So I went with a 32'' Ididit column, 2 joints, a floor mount, and a column drop. If I can get away with using 2 u-joints do I still need a support bearing for the shaft? Is it possible to use only 2 joints with a setup like mine or would that be putting too much of an angle on them? Thanks.
Old 12-03-2009, 10:06 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
With only 2 steering joints you won't need a support bearing. For most of the popular steering joints (Borgeson) 30 degrees is the max angle you can run without issues. If in doubt, get a degree wheel and check the angle when you have it mocked up. A small adjustment of the column can make a big difference in the linkage angle.
Andy
I have a Model A Pickup to build, have Lots of questions. 88lowrider General Rodding Tech 103 05-14-2009 09:46 AM
Question on 66 Mercury Comet steering and brake issues....... onebadmerc Suspension - Brakes - Steering 5 01-11-2007 05:41 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Problem: Steering Rack? horvath Suspension - Brakes - Steering 64 06-15-2005 08:11 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
