Getting the timing right on a 383 with Vortec heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2008, 12:57 PM
Hey everyone. I'm getting ready to fire my new 383 up. I have a comp 268XE cam and vortec heads. I believe compression will be about 9.7 to 1, and I'll be pumping 93 premium. I wanted to ask what base timing numbers should I be setting it to, intial? advanced? The more I look, the more confused I make myself. Thanks!
Old 04-29-2008, 01:31 PM
Drewnashty's Avatar
sitis nam accelero
There's no golden rule that if you have this you must use this timing, it's more of a trial and error. Adjust to what your engine likes, play around with it. My 383 with TFS 195 heads and about 9.6:1 CR likes 17 initial 35 total. But you will probably see all kinds of figures if everyone just started posting their ignition timing.
Old 04-29-2008, 01:37 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Vortec chambers are very efficient and will probably require less timing than conventional designs. Start at 32* initial/centrifugal.
Old 04-29-2008, 02:49 PM
F-BIRD'88's Avatar
Yada Yada Yada
Something between 12 and 16 initial is good. Something between 31 and 36 is good for a total mechanical. I found very little difference between 32 and 36deg.
On my vortec motor. The initial timing (separate from the total) has more effect on performance. (ET on a drag strip pass)
The total timing can be determined by watching the MPH on a drag pass.
If /when you find that 32 to 36 don't change the MPH much, use the lesser.
Improper carb jetting or lack of top end fuel volume {fuel starvation} (way too rich or way too lean will want more timing that expected normal(s).
Something around 10 to 15deg of additional vacuum advance for P/T hiway cruise is good. You have to dial in the advance rate (slope) for whats best.
It's up to you to experiment within these parameters to fine the sweet spot.
I found Champion RS9YC RS10YC or RS12YC spark plugs work very well in vortec motors.
350 Vortec heads on a 305--good idea? Ozz1967 Engine 5 12-04-2007 06:26 AM
Cast iron vortec heads scapegoat Engine 5 06-11-2007 06:21 PM
How much power can I expect from stock 305 Vortec heads produce? Lil Big Mec Engine 3 03-07-2007 08:50 PM
vortec vs phase 2 heads 71vegagt Engine 3 01-29-2006 05:12 AM
383 stroker with AFR heads - never fired. Make me an offer.Need cash fast for project elukas Engine 0 02-06-2004 01:53 PM
