Getting the window seated - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2007, 02:34 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: It tows!
Hello. I have a '64 Nova wagon. The right front passenger door window channel let go of the window. Now I have a replacement channel. It's in the door but I can't get the glass to seat fully with the rubber piece inside the channel. There's not much room to work with and I'm trying not gut the door. Any suggestions?
Old 06-09-2007, 02:39 PM
boatbob2
window........
i had the same problem,i bought a tube of the caulk that is used to glue windshields in. NAPA auto parts) remove the entire rubber in the channel,shoot the caulk in,putwindow in QUICKLY,this caulk sets up fast.
Old 06-09-2007, 02:45 PM
strummin67's Avatar
My problem is getting the glass and the rubber fully seated IN the channel.
Old 06-09-2007, 03:05 PM
Countilaw's Avatar
Cox Custom Cars
I saw a glass man do it once. He sprayed a lubricant on the rubber and channel and the glass and rubber just slid right in.
Call a glass place and see what they use. It may have a a penetrant like WD-40.
Old 06-09-2007, 03:29 PM
strummin67's Avatar
I'm afraid I'll have to gut the door. (What I was trying to avoid). The opening is not big enough to get the window out of the door. That looks like the only way I'll have any full access to the window and the channel. I'm worried I won't be able it get the window and the attaching channel back in. as it is I'm having trouble removing the vent window to free the side channel.
Old 06-09-2007, 03:41 PM
strummin67's Avatar
OK the window regulator is off and out of the way. Very little motion with the vent window/channel. I guess next is the door latch remote assembly.
Old 06-09-2007, 04:22 PM
strummin67's Avatar
OK. I've hit a snag.
The remote door latch arm connects to a shaft that connects to the actual door latch. Two of the screws holding the latch on the end of the door are holding fast and won't budge. On the other end, the piece that goes through the door for the inside latch handle is being held on by some some sort of fastener. I can't see how to get this fastener off with out breaking it.
ID:	21768   Click image for larger version
Old 06-09-2007, 05:12 PM
strummin67's Avatar
Well boys and girls, that ol' watch of mine says it's time to move on to something else. Thanks for your help.
Old 06-09-2007, 06:52 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
H,mmmm well gee..can you get the window free of the regulator..I don't remember all that much difficulty removing and installing one of those..
Sam
Window channels and removing vent window Jackyl Interior 11 10-10-2007 08:01 AM
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-25-2007 12:40 AM
Window channel problems.... onebadmerc Body - Exterior 4 03-25-2005 05:42 PM
Power Window Problem Steven_O' Electrical 2 03-29-2004 02:09 AM
Before I break it m-hauler Body - Exterior 16 07-20-2003 06:40 AM
