Ghost Flames?
Need some advise. I'm concidering something like these flames for the truck. Were these done with a light dusting of white or silver? They look like something I might try to do. Look fairly simple and subtle. I'm not sure you would call these ghost flames?
http://www.hotrodders.com/gallery/sh...hp/photo/33556 Dave |
A ghost flame is done with a pearl mixed in..Just spraying a smidge of paint on the area you want ghosted. Can be silver can be white..maybe gold..or something else that has a contrast to the underlying base..
Takes some practice to do it so if one wants to do that one buys some materials and practices to get the effects one desires.. Sam
Need to add another question, paint related. Have you ever sprayed a clear coat on top of single stage for a glossier finish? I was told by some, yes, and by others, no. I'm no pro so I need the extra layer of clear to give me plenty to ultra-fine and buff to a gloss. I've always used PPG base/clear systems in the past but painted my RX8 with a single stage. I really wasnt too happy with the single stage. Any thoughts? Dave |
Sorry everyone. I just noticed that someone just asked a similar question a couple days ago. I'll search better from now on to help stop the redundant questions.
Dave |
I would put the pearl in the clear myself..Sorry was not clear on that point...Yes you can shoot a clear over a single stage base..works just fine..
Sam
Thanks, Dave |
Those flames look Great
Shane |
mid coat or intercoat is a clear that flashes off like a base coat (DULL).This clear is used as a transporter of pearls or metallics to get them onto the surface. It is also used if you are gonna do some artwork on top of open basecoat,it helps protect the fresh base coat from tape tracks. This is what i would suggest you use this way when you clear all your work if you happen to get a flow indicator (run) lol it will be in just clear not your pearls which will cause more problems than you want . good luck
Dave |
They look even better when the car is cleaned and freshly waxed too (a state of being which is all too fleeting with this car, unfortunately). |
| low priced spray gun/detail gun for primer/base/clear and ghost flames | jrmy_1 | Body - Exterior | 15 | 06-08-2008 06:38 AM |
| Ghost Flames Plan of Attack | rockitdoc | Body - Exterior | 9 | 12-03-2005 08:31 PM |
| An Amateur Tries Ghost Flames | rockitdoc | Body - Exterior | 13 | 12-02-2005 09:46 PM |
| ghost flames | pichoboxing | Body - Exterior | 9 | 03-23-2005 08:07 PM |
| Ghost flames | chevyelc81 | Body - Exterior | 4 | 04-08-2004 07:10 AM |
