Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ghost lines from welded patch panels
  #20 (permalink)
Old 01-07-2011, 02:31 PM
cjperotti cjperotti is offline
You will see butt welding on a lot of forums that doesnít make it the best recommended weld available. It is the stupidest weld to use on any structural repair or replacement panel period.
ASI and most manufacturers donít recommend butt welding replacement panels and for a reason. If you want to butt weld do so at your own risk.
