Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ghost lines from welded patch panels
  #23 (permalink)
Old 01-07-2011, 03:56 PM
spitfire481 spitfire481 is offline
Originally Posted by swvalcon
I've been doing this for 40 ys and the only time I've seen this happen is back in the days when we used bass and a torch. You didn't use a flux coated wire by any chance did you.
no flux core wire. welder is the same setup the guys use for all the shop collision work. theres not a lot of butt welding on there side that i see but we have never had anything come back because of ghosting issues. like i said if the panel had a factory-ish peel to it, it would hardly be noticeable. but when the panel is flat it stands out.
