Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ghost lines from welded patch panels
  #25 (permalink)
Old 01-07-2011, 05:42 PM
Underground's Avatar
Underground Underground is offline
Last journal entry: 54
Originally Posted by spitfire481
the pocket has to stay there, cant be cut out because the inner handle/latch assembly is built to work with the pocket in the sheet metal. if i overlapped on the outside i beleive the area would be too high for me to be able to make the handle work proerly. the patch is welded in flush with the door skin but i also drilled some holes in the pocket from inside the door so shoot rust fighter in there for protection.
He didnt remove the pocket he shaved so the "structural integrity" is still there.
