Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ghost lines from welded patch panels
  #28 (permalink)
Old 01-07-2011, 05:05 PM
cjperotti cjperotti is offline
Now that you've supplied pictures of the actual project it is different than I imagined. Flanging would be difficult to say the least; however, not impossible. Ninety degree cuts would have to be implemented and then bent in slightly with pliers.
Underground good research. However, I disagree with the authors statement that I-car doesn't recommend flanging as I took courses where they used demonstration videos using that very method.
