Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ghost lines from welded patch panels
  #30 (permalink)
Old 01-07-2011, 06:44 PM
Underground's Avatar
Underground Underground is offline
Last journal entry: 54
Originally Posted by cjperotti
Now that you've supplied pictures of the actual project it is different than I imagined. Flanging would be difficult to say the least; however, not impossible. Ninety degree cuts would have to be implemented and then bent in slightly with pliers.
Underground good research. However, I disagree with the authors statement that I-car doesn't recommend flanging as I took courses where they used demonstration videos using that very method.
1) how is flanging this piece going to do any good? How are you going to weld the flanges to anything (through in inside of the door?
2) I didn't do the research. Freethinker did.
