Ghost lines from welded patch panels - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 01-08-2011, 07:34 PM
poncho62's Avatar
Wiki Edits: 5
Acting like a tool has nothing to do with free speech.......Take a couple of weeks to think about it.
  #47 (permalink)
Old 01-08-2011, 08:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Was the original reason the handle 'cup' was covered up, purely cosmetic? I doubt the aero advantage would be very much, if anything.
Seems labor intensive as hell for not much of a change in looks, plus it would seem the utility would be adversely affected- like real hard to open the door wearing winter gloves, good chance the paint could become marred from use, etc..
  #48 (permalink)
Old 01-08-2011, 09:00 PM
Iím not a fan of shaved door handles myself. But then, some door handles are just so ugly they warrant removal by any means.
I thought spitfires concept quite novel and refreshing coming up with a new approach to addressing an otherwise boring door handle. Sure there may be some problems as you mentioned Iím sure heís already aware and accepted them.
If we took into account the value of results compared to the labor and expenses for every project they would have been destined to the scrapyard before projects were started. Thatís the nature of this trade. Great results little reward.
  #49 (permalink)
Old 01-09-2011, 10:01 AM
its all cosmetic. opening the door is really no challenge at all. i can pull the handle without touching the door panel at all. been a year and not one scratch around that area. car does not see winter. might as well post a few shots of the car now
  #50 (permalink)
Old 01-09-2011, 10:07 AM
Great job! I like the look of the door handles. Also like your heavy duty hood prop.
  #51 (permalink)
Old 01-09-2011, 10:10 AM
life is a temporary assignment
Originally Posted by shine
and yes mig welds are harder. most times when they ghost it's because too much weld was left .
Very true shine.. I have to say, It's how you dress the weld's that have a lot to do with it.. I MIG weld everything on all the cars I do.. Never seen where it caused a problem yet.. Again.. It's in the finish work..
By the way.. Very nice car..
  #52 (permalink)
Old 01-09-2011, 10:31 AM
Any pics of what "proper" dressing looks like?
For strength, I've been not going all the way back to level, since when you get close it is hard to tell when you are still removing weld, or the surrounding metal.
  #53 (permalink)
Old 01-09-2011, 11:42 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Guys you are doing practice coupons are you not..when you get good penetration to the back side then you can dress the weld right down and have the strength of the weld..
sam
  #54 (permalink)
Old 01-09-2011, 12:00 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Here's some welds taken right down.
I don't think I'll run into trouble.
Name:	IMG_0536 (Small).jpg
ID:	51510   Click image for larger version
Name:	IMG_0532 (Small).jpg
  #55 (permalink)
Old 01-09-2011, 12:22 PM
Underground's Avatar
Last journal entry: 54
x2
  #56 (permalink)
Old 01-09-2011, 01:18 PM
Onemoretime explained it right..
Being I'm working on a glass car right now.. No.. I don't have pictures.. But I will try and explain what I do.. First I make sure both side are very clean.. I then butt weld everything.. The key is.. Learning how to spot it hot.. You want 100% penetration.. You can practice on some scrap metal.. I weld everything a Little hot.. Getting my 100 % penetration.. Then carefully grind down the weld, Only on the outside.. When done right... You won't even know there was a patch there.. I hope this explains it..
Patch Panels srb23 Body - Exterior 3 09-02-2009 11:43 PM
I welded in my first patch panel, need help grinding welds 87SS Body - Exterior 25 09-23-2008 08:22 AM
Patch Panels ARPEE Body - Exterior 2 08-17-2004 10:35 PM
patch panels SJU Body - Exterior 3 06-04-2004 06:31 AM
Patch Panels BLOWN 1100 Body - Exterior 1 09-15-2003 08:18 PM
