Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Give me some ideas on prepping this thing
  #59 (permalink)
Old 11-18-2012, 07:19 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Originally Posted by 69 widetrack View Post
Dead is right...I use my 16 1/2 by 2 3/4 inch long board more than any other tool for getting a car straight...with the sheet roll system you can get any grit you want for body work or finish sanding in dry paper. I don't know about you dead but I haven't used my air board since I stopped working flat rate, even then I trusted my long hand board more, a lot lighter so less pressure on the panel and no noise to speak of.
Ray
I still have my air board but rarly use because I start sanding my bondo before it gets hard by hand but occationally, on a big panel I cant move fast enough and the filler gets hard so I have to break it out.pretty much ALL my filler sanding is done by hand too..
