Yes, I know I don't need to say this but I will anyway...just be sure you block it no matter how straight it looks, if you block with 320 then a quick guide coat in between the 400...and go over it again with a soft block with 600 you should be OK. The reason I say guide coat in between 320 and 400 is to get rid of the 320 scratches, you'll see what I mean when you do it.
Is this the epoxy you used on your Nova???and you mentioned it sands well?
Ray
