Give me your ideas - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2006, 09:26 PM
joeford's Avatar
36 Dream
Last journal entry: The fire...
Give me your ideas
I'm building a 36 ford Coupe and will be going with a 350 Chevy SB, 700R Overdrive, 9"ford, 370 posi.
Car will be used as an occasional street/strip machine...Mostly occassional street machine.
I'd like to have a just enough lope to know that the cam is not stock and I'd like to have between 375-425 hp.
I'd prefer 3 dueces, but have to keep maintenance to a minimum since I'm not a mechanic. Although I have friends that are and I'm not opposed to an annual adjustment... Since low maintenance is cruical I would also consider ram fuel or 4 barrel setup.
Who can recomend a reliable, trouble free setup that meets the above profile?
Old 01-30-2006, 10:13 PM
MI2600's Avatar
Member# 3287
Try this site and take your pick:
www.ryanscarpage.50megs.com/combos1.html
Old 01-30-2006, 10:33 PM
tbirdscott's Avatar
stuff'n things'n whatnot
Something like this would be your best bet.......
Old 01-31-2006, 11:51 AM
350 with Flat top pistons
AFR 180 cc, Trick flows, or 180cc Dart Iron Eagles with 64 cc chambers
CompCam 270H mag
2200 stall
Performer RPM intake
Holley 750 cfm with vacuum sec. (model 3310)
HEI with MSD conversion
Mallory comp110 fuel pump
Roller rockers
Hooker block hugger headers
Should be good for 385 to 400 hp with 400 ftlb of torque.
Old 01-31-2006, 04:10 PM
firestone's Avatar
http://teamrfc.gospelcom.net
These heads are not cheap, but they are worth it. I think this setup would work very well.
http://airflowresearch.com/articles/article40/A-P1.htm
Adam
Paint Scheme Ideas IWANTMOREHP Body - Exterior 6 02-20-2004 10:52 PM
Ideas anyone? 78 GMC P/U good for a hotrod? nuch69 General Rodding Tech 11 09-13-2003 07:10 AM
annivrsary ideas 38 special Hotrodders' Lounge 16 05-17-2003 11:07 AM
retro lookin truck ideas? jon_volk Body - Exterior 2 02-11-2003 07:56 PM
Tubbing My Truck, need some ideas. F-1Rodder Body - Exterior 4 02-17-2002 04:30 PM
