glass chanel repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2004, 06:56 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
glass chanel repair
hi guys, i'm repairing some rough spots on the rear window and windshield lip of my 66 impala the problem is that a few of the soft spots are around the studs that hold the molding clips on. if i have to replace a section of the channel that has the stud how do i replace them? is it OK to leave a few out? or do they make replacements that i can rivet back in? i'm not sure what to do. thanks in advance for your input.
Old 09-02-2004, 07:07 PM
BOBCRMAN@aol.com's Avatar
I usually just use a pop rivet
Old 09-02-2004, 07:12 PM
helrazr3's Avatar
i thought of that but the stud looks like the head of a nail with a flat head on it. do you need that "hat" on the stud to hold the clip?
Old 09-02-2004, 07:26 PM
You could probably grind down the OD of the rivet. I usually just let the rivet head ride on top of the little plastic goodie. There is usually room for it.
Old 09-03-2004, 11:23 AM
window trim clip retainer pins
I have used sheet metal screws to hold the clips on. The rivits sound to be about the same. The only bad part of either of these is that they have to be put in before the window goes in.
Old 09-05-2004, 11:52 PM
helrazr3's Avatar
thanks for the input, i just finnished blasting the channel and hopefully i think there is only one pin that might be in trouble i think i can save the rest.
