Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - glass fuel filter half full of half empty.
Old 09-21-2011, 07:35 AM
UPandComing UPandComing is offline
B.A.M.F
I would suggest removing said filter, clean it thouroughly, while u have it off remove the fuel line from the manual pump that leads to the tank take the gas cap off and use a small amount of compressed air and blow through the line there may be sediment clogging the line in the tank reinstall and see if that fixes things, that would be the first step i would take jope that helps
