glass sweeps - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2010, 10:44 AM
Mrwood's Avatar
Last journal entry: My 1962 Falcon
glass sweeps
What kind of glue can i use to attach my sweeps to my window mouldings on my 48 chevy.
Old 03-10-2010, 01:05 PM
DanTwoLakes's Avatar
Wiki Edits: 22
They are not attached with glue, they are attached with mechanical fasteners. You can use staples (like they were from the factory), stainless steel or aluminum pop rivets, and small stainless steel screws. The best place to buy the sweep (which is called belt weatherstripping) is through J.C. Whitney. You can get a 6 ft. length of it for under $20.00.
The one in the picture was re-attached with regular screws, which I will replace with stainless pop rivets when the time comes to install new weatherstripping. The screws are sticking up because I loosened them, they disappear in the flocking when they are tight, as do the staples and pop rivets. You can see the original staple holes in the '48 Chevy window molding in the other picture. If you're a real glutton for punishment, you can try using the staples which are available HERE I know it says 58 to 64 Impala, but all Chevies used the same ones until 1967.
ID:	44423   Click image for larger version
ID:	44424   Click image for larger version
Old 03-10-2010, 01:56 PM
Mrwood's Avatar
glass sweeps
Thanks Dan, i was thinking of screws at first, but i thought they would rub on the glass. Thanks again. How do i do the outside, wont the screws go through my trim.
Old 03-12-2010, 08:10 AM
Wiki Edits: 22
The outside sweeps are done the same way as the ones on the window molding. Don't let the curve at the end of the outside sweep throw you, the belt weatherstripping can be formed to match the original.
ID:	44458   Click image for larger version
ID:	44459   Click image for larger version
Old 03-12-2010, 02:50 PM
Mrwood's Avatar
glass sweeps
Thank you very much for all your time and help. Its going back together now. Where is the best place to get my glass channel, i want to use flex channel without the stainless steel bead, since i have made my door glass longer. I tried some with the bead and then my inside molding would not go back on.
Old 03-13-2010, 08:57 AM
Wiki Edits: 22
I like C.R. Laurence. CLICK HERE
Old 03-15-2010, 10:51 AM
Mrwood's Avatar
glass sweeps
Ok i got the drivers side door all done, just have to have the glass cut. Thanks for all the help.
Cutting glass by sandblasting, Urban Myth? MARTINSR Body - Exterior 61 01-03-2015 09:48 PM
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-25-2007 12:40 AM
chopping top on truck levittmotg Body - Exterior 20 03-22-2006 09:42 PM
Is all laminated glass equal? cboy Body - Exterior 11 05-20-2005 07:25 PM
windshields bill66di Body - Exterior 15 07-31-2004 08:31 AM
