Glasspack vs. 40 series - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2010, 12:27 PM
which gives off better sound which is louder
Old 06-23-2010, 01:39 PM
In my opinion glasspack is louder but i hate the derby car sound they make. I like my 40 series flowmasters a lot, loud but not to loud, and less resonance
Old 06-23-2010, 01:45 PM
FastOrange's Avatar
have glasspacks on my ford, sounds like **** but is super loud
have a 40 on my chev, sounds awesome and is still really loud.
Old 06-23-2010, 03:10 PM
I have been told that the glass packs are horrable for performance and act like a cork in your exaust. Its just my opinion but I think you should worry more about performance rather then sound. Dont get me wrong, I love a nice big exaust, But I rather have GO then SHOW/ SOUND. Thats just my opinion though, its YOUR car after all
Old 06-23-2010, 05:29 PM
The last truck I had, had glasspacks on it. I never knew what it sounded like as an "outsider', since I was always driving it. The day I sold it was the first time I heard it...and it was being driven away...forever . Realized at that moment that it didn't sound like a typical car/truck with glasspacks. Under a typical/stock car, glasspacks sound like crap ("blatting" sound). But combined with the right engine set-up/exhaust system, it can sound pretty good.
Old 06-23-2010, 08:06 PM
Irelands child's Avatar
I have 3 chamber Flowmasters on my AVATAR car. When they were new, they droned. Seems to be gone now - and they are getting nice and rumble-y. I do have an 'H' pipe to cancel some of the harshness out as well. My last glass packs were on an old Ford Torino wagon with a nice 351C. They lasted about 2 weeks - gawdawfull loud - then turbos were installed. Great sounding then.
Dave W
Old 06-23-2010, 08:20 PM
Dave W
Dave were the turbos thrush?
Old 06-23-2010, 08:50 PM
I've ran alot of different mufflers, exaust is usually the first thing I do to a car lol. In my experience at least 50% of what they sound like is exaust system design & size. I have 3" exaust(w H-pipe) on one of my cars with 40's that dump in front of the axle and it sets off car alarms in the Wal-mart parking lot with its resonance. Then on my K5 I have 2 1/2" pipes w 40's and dumps and it purrs like a kitten, I was actually disapointed at how quiet it was. I dont run an H-pipe on that one.
With glasspacks I've found that length plays key role. My 1st set I wanted loud so I got some 18"ers...very noisy but crackled good under acceleration. I had the same basic setup in a pickup, but w 24"ers and while it wasnt as loud at idle I thought it sounded way better when you got on it. More the "glasspack" sound...
Oh, & as a side note most glasspacks have a 2" core no matter what the bushing dia is(hence the term "cork" lol). AFAIK all 40's have a 2 1/2" hole in the baffle no matter what bushing size(but there may be variences on either)
If I was doing all new exaust I would go for 40's simply 'cause I like the sound alot better and they last forever. If I went glasspacks I'd go at least 20-24", the 18's sucked IMHO.
BTW I just put 3" Spintech Pro-shootouts on my street truck...talk about F-ing LOUD, I welded up all the pipe, took her for a spin & my brains just about ran out of my ears from the resonance. I added some side exiting pipes(it had turndowns under the bed) and that seemed to cure that problem but still Xtremely loud. Sounds good though! lol
Later guys- John
Old 06-23-2010, 09:00 PM
I know everyone has their preference, but I enjoyed a pair of these on my 85 Monte Carlo SS. http://www.dynomax.com/mufflers.php?muffler=racebullet I put those on to replace a set of Thrush, and they sounded alot better.
Old 06-23-2010, 09:53 PM
there going under a 85 monte carlo with a built 383 stroker my biggest thing is them being loud at an idle
Old 06-23-2010, 10:37 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
383 and glasspacks, definitly loud. Flowmaster 40's would make that puppy purr
Old 06-23-2010, 10:45 PM
I enjoy the Super 40 Flowmaster on my 1980 Z28. Sounds nice deep and throaty but is a bit loud in the car. If you want interior noise to be lower, try the deltaflow 40's. You can go to flowmaster's website and listen to the different mufflers they offer yourself. The 85 Monte I had, had a stock 305 motor so the dynomax bullets werent overpowering. Good luck on your search.
Old 06-23-2010, 11:16 PM
I have a 305 in my 86 C-10 with bolt ons and it sounds nasty, well to me. I have 40 series flows. I had turbos at first but the cab was very loud. Flows are quiet inside the cab
Old 06-24-2010, 12:22 AM
Silverback's Avatar
Boost Retard
WOW! I'm downright shocked how many of you like the flowmasters. I find them metallic and annoying sounding, and most drone and resonate at midrange rpm's. The super 40's sound significantly different then all the older designs, and are more mellow sounding then the rest, even then the deltaflow, 50 and 70 series mufflers. FWIW, a lot of their designs can be super restrictive, it's not uncommon to loose HP with them.
Longer glasspacks generally sound pretty good, shorter ones can have annoying qualities, but work really well with setups that have other pieces in the exhaust that cut down noise (converters, turbos...). They flow fine as long as you make sure that you have full size flow tubes.
FWIW, I generally dynomax ultraflow welded mufflers in applications where performance is the primary concern (basically a straight through design like a glasspack but with a larger case that controls annoying noises better), and Hooker Aerochambers sound absolutely awesome (and still flow almost as well as a straight through setup).
Old 06-24-2010, 04:41 AM
They were Walker's
Sanding "bondo" with 40 or 36 a No-No! MARTINSR Body - Exterior 44 05-15-2006 09:32 PM
The end of the 40 Series Originals? phat48 Hotrodders' Lounge 4 06-23-2004 02:51 PM
Super 40 vs 50 Series Delta Flow dannimo Engine 3 01-27-2004 03:16 PM
Super 40 or 50 Series DF dannimo Engine 0 01-19-2004 09:25 PM
flowmaster 40 series delta or original flows fordracing Engine 6 06-06-2003 03:46 PM
