Glazing putty, When? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2003, 04:07 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
Post Glazing putty, When?
OK, I know I've been asking alot of questions, and some may have been a little off the wall but I've never painted a car before, so the only dumb question is the one I don't ask and mess up all my work,so heres another one.
When I've been doing some of the filler work needed I've gotten a couple of small air bubble holes in it, is it alright to fill these with glazing putty?? They are very small but I don't really want to add more filler.
Thanks for understanding what I don't.
Old 05-13-2003, 05:25 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Post
Sand them out and redoit, or use two part urathain glaze, it workes for me. A good quality filler wont give that much trouble, Put it on and leave it alone, don`t keep trying to get it smoother. good luck
Old 05-13-2003, 06:17 PM
mitmaks's Avatar
Last journal entry: Grille
Post
i wouldnt use it on show car.
Old 05-13-2003, 07:33 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Well, I would say definately use the glaze. I am wondering if there is some reason the above posters say not to. I use the crap out of it. I usually coat the entire area of filler and sand it smooth. Then prime, sand, seal. It is next to impossible to get filler sanded out with no air holes in my experience. You have two choices: lots of high build primer to fill the pin holes or glazing putty.
Any pros want to jump in with the "right" answer....HK....CollinsMoCo...TLambert
Chris
Old 05-14-2003, 04:52 AM
Dragon J's Avatar
Last journal entry: Harley/Fire
Post
IMHO..... I fill and smooth as good as I can get, prime with high build and wet sand as smooth as possible, then fill the little imperfections w/glazing putty (catalyzed) sand smooth, prime or seal one final time- wet sand and color coat. If it is sealed or primed the 'spot putty' is no different than thick primer- won't hurt a thing...(again in my humble opinion!)
Old 05-14-2003, 05:28 AM
troy-curt's Avatar
Post
If you fill the sand scratches and air bubble holes with primer or plain glazing putty, it will shrink after you paint, and show through.
I build show cars and street rods. I buy my glazing putty by the case.(2 part urathain)
It will not shrink. You should sand of all you can. The camaro in my Avaiter (?spelling?) was painted in 94 Still no shrinkage. In 98 it won
overall Grand champion ISCA (world of wheels)It is still showable.
Old 05-14-2003, 04:41 PM
TurboS10's Avatar
Wiki Edits: 2
Post
Where do you guys get the two part putty? All of the stuff at my local store is one part....at least what I have seen and used. I have noticed that the uncatalyzed stuff always shrinks a bit after application. You have to let it cure for a day or two before sanding it or it will shrink like mentioned above. I usually just shoot a coat of build primer after the putty and then sealer. Never really had problems with it showing through after that, but it would be nice to use some catalyzed stuff.
Chris
Old 05-15-2003, 08:26 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I thought that is what the glazing putty was made for - to fill scratches and bubbles! Anyway, go to your local automotive paint supplier. They should have several types of Evercoat 'bondo' type glazing putty which is about as good as you can get. I have never asked why there are several types, I just always get the blue stuff. Guess I should ask, huh?!? Is basically a high quality, very fine textured bondo that goes on just like body putty but fills, feathers out, and sands easier than the regular body filler.
Incidentally, the blue Evercoat glazing putty is the ONLY thing to use in customizing plastic models.
Old 05-15-2003, 12:42 PM
Post
All one part glazing putties will shrink. But only in the first day or so. You must leave it for a day or two before sanding.
If you want a quicker method go to a hobby shop and get two part epoxy putty. Dries quickly, sticks like hell, doesn't shrink, water and solvent proof.
For larger repairs I use the less exensive plumbers epoxy putty from Home Depot. Much cheaper than the hobby store putty but not as fine. Both sand easily and finish smooth.
Old 05-15-2003, 06:48 PM
New Member
Post
Just put a real thin coat of polyester bondo on it. u should be able to wet sand it if u wish.
Old 05-15-2003, 10:07 PM
Mirror Image's Avatar
Post
I have used evercoat polyester puttie for years its 2 part and will not shrink give it 20 min or so and block sand it with 180 grit dry paper and prime with high build 2 part primer
Old 07-19-2004, 10:26 AM
TonyO's Avatar
So basically what everyone is suggesting is the 2 part putty?
Old 07-19-2004, 10:38 AM
troy-curt's Avatar
I use putty-coat mastic/polyester glazing and spot putty by bondo.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 07-19-2004, 01:29 PM
TonyO's Avatar
So how does the spot putty glaze from Bondo work out? Does it shrink at all?
Old 07-19-2004, 01:44 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
my exp. with the bondo spot glazing putty has led me to the conclusion "it sucks."
get the 2 part stuff by rage. trust me.
catalyzed = 2 part. yes.
not to be contradictory to Troy. he gets cranky like that....
