Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - glove box
Thread: glove box
Old 08-10-2005, 04:45 PM
Derkyb's Avatar
Derkyb Derkyb is offline
ditto
They make a underdash radio mount, sort of a holder, that screws to the bottom of the dash. I bought one of these and cut it to fit the glovebox then I used the metal supports that came with the radio,usually used to secure the radio behind the dash, to support the cardboard glovebox. Then ran small bolts through the holder to the supports to mount the radio in the glove box.
It would probably work better if you put a flat piece of sheet metal behind the cardboard then run screws through that.
