Glove Box lock - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2004, 07:27 PM
Paintbug's Avatar
Glove Box lock
Hoping someone can help me out. I have a 72 Chevelle. I ordered a new glove box door and I have to take the lock out of the old one to put in the new one. For the life of me I can't figure out how to get the lock assembly off the old one.
Old 11-29-2004, 06:50 PM
BradOlive's Avatar
New Member
Grab a nail and pop your lock....
Open the door and pull the latch up into the closed position and then pull it even farther ( as far as it will go and then hold it in this position). Take a small nail or paper clip and insert it in the small slot ( located at about the 3 O' Clock Position ) in the back of the cylinder casing. There will be 3 or 4 spring loaded small metal keys (don't know the correct name for them) that you will need to depress one at a time while pulling on the outer chrome bezel. As you get by one another will catch and you will need to depress it to get by it. Remember, while doing this you must be holding (or wire it) the latching arm all the way up as far as it goes. As you get by the last key? the cylinder will pull all the way out. Then you can unscrew the threaded part that holds the casing to the door. The two parts unscrew and seperate from the door.
http://personal.riverusers.com/~mcphelps/glovebox.htm
Check out these pictures on how to remove it.
