glowing #5 exh. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-26-2010, 09:24 PM
ericnova72's Avatar
More for Less Racer
If this is a Fel-Pro Permatorque Blue gasket you used(light blue w/dark blue stripes and thin steel shim in the center layer) you have the wrong gasket for an aluminum intake. That gasket is made for the expansion and contraction rates(due to heat) of cast iron to cast iron joints, it will often leak after being heated and cooled a few times using a higher expansion aluminum intake.
Correct gasket will be the Fel-Pro Printo-Seal(or equivilant from MR Gasket, Edelbrock, ROL), which is a black or grey fiber gasket w/ a blue, red, or orange silicone bead printed onto it, around all the ports
  #17 (permalink)
Old 10-26-2010, 10:31 PM
ill check into the gaskets. DAMN! but it all makes sence. so ill chang it all out here soon and hope for the best.... this makes me sick..uggg!
  #18 (permalink)
Old 10-27-2010, 06:21 AM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by Double_v23
The picture of the plugs doesn't tell the whole story, and the right way to read plugs involves being able to see the base of the ceramic INSIDE the threads. So anyone who gives you a reading based off of those pictures is just guessing. Reading plugs is an art and is difficult to do even with a magnifying glass on a sunny day, doing it right from a pic is almost impossible.
In some cases you would be correct. In this case however there is such a huge difference in the plugs it is quite obvious that there is an issue in the one cylinder. There is a night and day difference. He has one glowing header and one white plug from the same cylinder, I dont see how anyone can debate that that cylinder is lean. Cam timing, ignition timing would affect all cylinders, not just 1. Plug reading is an art under some conditions but this one is pretty obvious.
I personally dont like his choice of plugs either
Chet
  #19 (permalink)
Old 10-27-2010, 06:36 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
SOMEhow, #5 is burning lean. I'd be looking for an intake leak on that cylinder...
  #20 (permalink)
Old 10-27-2010, 12:30 PM
You need more timing. big cams need lots of timing at idle. 18 isn't enough.
all the cylinders are getting hot (not just #5).
try 25 at idle and see what happens.
after you set the timing, adjust idle mixture screws for highest rpm (highest vacuum)
a lean cylinder will not glow the header red at idle.
  #21 (permalink)
Old 10-27-2010, 12:33 PM
read this
http://racingarticles.com/article_racing-56.html
  #22 (permalink)
Old 10-27-2010, 06:13 PM
ericnova72's Avatar
More for Less Racer
I'll be the second to tell you to get those goofy "gimmick" plugs out of there. There is no advantage to them over a conventional plug, they just lighten you wallet and confuse tuning issues.
Lean mixture can glow a header tube...if it is so lean that it doesn't burn correctly in the chamber and is still burning when the exhaust valve is open. Plug shows so lean it may be a virtual misfire situation in that hole. Back to the possible gasket situation sucking air.
  #23 (permalink)
Old 10-27-2010, 06:51 PM
not glowing at idle only at hwy rpm's. i found out that i used the wrong gasket i guess. i used the felpro with the steel inside. so i just ordered up (felpro 1205) and they will be here in the morning. after further investigation all but the front tubes were glowing at that rpm just #5 was the first and brightest. i checked with lights on low in garage. sorry about the plugs..i cant please everybody.
  #24 (permalink)
Old 10-27-2010, 07:17 PM
345 desoto's Avatar
Since you've already got the plugs, and they're working, I wouldn't loose any sleep over them...
Glowing Headers Koolaid Engine 6 07-12-2007 10:30 AM
Glowing Turn-Signal Indicator horvath Electrical 2 07-24-2006 10:19 PM
383 startup timing/mixture glowing headers guba_unus Engine 20 11-20-2005 11:24 PM
2 Exhaust Pipes Glowing Red Hot (Part 3- The Head is Off !) white66coupe Engine 15 11-01-2005 04:08 PM
2 Exhaust Pipes Glowing Red Hot (Part 3 !) white66coupe Engine 12 06-14-2003 08:07 AM
