I don't see changing the fuel filter as the problem, but lean more to something happening to the timing instead. Could be a computer problem...Sorry i'm not up on the new stuff.
glowing exhaust
you might have left a vacuum line off when you installed the filter.
there is no catalytic converter. theres just straight pipes coming half way back and into a new muffler, which was also glowing. all the vaccum lines are hooked up and where they should be. the only other thing i did besides the filter was i hooked the air cleaner all up, with the vaccum lines and everything in place, and the breather filter. would that have anything to do with it? this one has me stumped. its almost like its running lean, but i cant adjust the carb. |
one of 2 things, lean mixtre or retarded timing. I would bet there is something wrong with your new fileter or its insallation.
| 2 Exhaust Pipes Glowing Red Hot (Part 3- The Head is Off !) | white66coupe | Engine | 15 | 11-01-2005 04:08 PM |
| New Exhaust and now the engine runs hotter... | nsane | Engine | 4 | 10-16-2005 02:30 AM |
| 2 Exhaust Pipes Glowing Red Hot (Part 3 !) | white66coupe | Engine | 12 | 06-14-2003 08:07 AM |
| 2 Glowing Red ExHaust Pipes Part 4-(I think I found something !) | white66coupe | Engine | 2 | 05-30-2003 03:40 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
